Results 1 to 9 of 9
Thread: How many hours per day should I run my pump?
    I have a 24' round (14k gallons or so), with as Hayward S180t and a Hayward Powerflo Matrix 1HP pump. Right now I have it set for 12 hours per day, mainly because thats what the previous owners had it set at. Any opinions?
    24' Round 14K Gallons
    Hayward S180t Sand Filter
    1hp Hayward Powerflo Matrix Pump
    Aquabot Pool Rover Jr.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,100
    Re: How many hours per day should I run my pump?
    As many as it takes is the only good answer.
    12 hours sounds high. Try it at 8 hours and see if your pool stays clean and levels stay good.
    22,373
    If that's a 2-speed pump I'd run it on low 24 hours a day. If it's a single speed I'd try 7 or 8 hours a day. I split my run times but the total per day is 8 hours.
    Cool. Thanks guys!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,768
    Quote Originally Posted by stavs
    A lot depends on the usage and what sort of debris ends up in the pool. 12 hours sounds like overkill to me. Unless you have a way to calculate flow, which is doubtful with an aboveground, just keep dialing it back. Maybe lose an hour every 3 days or something. When it starts not looking as sparkly as it did, go back up an hour.
    Well, with 12 hours, my water is clear, and I end up with a good bit of sediment spread around the bottom of the pool which the Rover Jr. takes care of (no vacuuming!). I dropped it down to 8 to see what happens. Considering it was keeping it clear with the return plugged (yes, I didnt realize there was a rubber plug behind my eyeball!), I figure 8 will be a good starting point.
    Aug 2009
    SW Wisconsin
    518
    I have a 1.5hp pump on my 33ft agp...I run it 24/7..that way I know the pool is always clean and clear.
    33' x 52" Swim and Play Inc. PARAGON AGP. Hayward H200 Heater. Hayward Power-Flo LX 1.5hp pump. Sta-Rite Cristal Flo T-210WF Sand Filter. Stenner 45M5 chlorine pump
    Jan 2010
    Randleman,NC
    620
    I have the same setup...I have mine set to run 4 hrs during the day &the same at night..Has worked pretty good for the past couple of yrs.I usually clean mine on Sunday's..So most of the time I will let it run on Sunday's so I can get a good set of test&good cleaning..Since I have changed to the BBB...My water has stayed clear & hold's pretty good with the shorter cycles of the filter running..That's just my opinion..I don't have a big problem with leaves,etc so I spend very little time vacuuming!!!
    Leasure bay AG 24ft,52 in high.installed June of 1999. Hayworth S-180 T sand filter/Power-Flo Matrix 1horse 2 speed pump /Aqua Trol SWG/Using TF-100 Test Kit
    Cherie's Avatar
    Jul 2008
    Wylie, Texas
    506
    I keep our 2-speed on low 24/7. The single-speed which came with the pool was costing us about $90/mo for 10/hr day, which is why we swapped it out with the 2-speed. The 2-speed on low 24/7 only runs about $30/mo.
    32x16 buried Doughboy, 4' shallow - 7' deep
    Pentair Dynamo 1 hp, 2-speed - Pentair 150# SD40 w/zeolite (75#)
    One skimmer/two returns/Aquabot Turbo T2
