Results 1 to 10 of 10
Thread: evaporation
    evaporation
    i am loosing 2-3 in of water a day in my 24 round. is that normal? i assume that is is because of evaporation but i am not sure. also we have had some very hot days lately temps getting up in the 100's. i just wanna make sure i dont have a leak
    24 ft round ABG 4.5
    2 hp pump with 200 lb sand filter
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,659
    Re: evaporation
    Where are you located, and how much sun exposure does the pool get in hours daily?
    Add a sig line in your profile so we know what you have and can help.
    22,553
    Re: evaporation
    2-3" is a lot of evaporation. I' suggest you do a bucket test.
    1. Fill a 5 gal bucket about 2/3rds full of water.[/*:m:lu8cqm7b]
    2. Place the bucket on the top step in your pool.[/*:m:lu8cqm7b]
    3. Carefully mark or measure the water level in the bucket.[/*:m:lu8cqm7b]
    4. Carefully mark or measure the level in your pool.[/*:m:lu8cqm7b]
    5. Wait about a day and measure the levels again.[/*:m:lu8cqm7b]
    If the bucket and pool loses the same amount it's evaporation. If the pool loses more than the bucket you have a leak.
    30,432
    Re: evaporation
    If your 2-3" estimate is pretty accurate, you have a leak.
    Re: evaporation
    i am in south carolina and the pool is in direct sunlight about 80% of the day. my wife says that it is more like 2-3 in every 2-3 days. that still seems kinda high to me.
    I will try to do the bucket test in a couple days. i never thought of that. i have looked for a wet spot around the pool but can not find one but i guess i could still have a leak even thought i cant see water on the ground any where
    24 ft round ABG 4.5
    Re: evaporation
    well i found out where my water was going. when the pump runs at night it leaks out of the discharge hose. what would cause that?
    24 ft round ABG 4.5
    22,553
    Re: evaporation
    You mean it leaks out of the waste hose on the multiport?
    Bad spider gasket is the most likely suspect.
    Re: evaporation
    yep that is where it is leaking at. it only leaks out there when the pump runs and it is a slow stady stream.
    24 ft round ABG 4.5
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: evaporation
    I agree w/ Bama; the spider gasket is almost certainly your problem. Easy, cheap fix!
    Aug 2009
    Hattiesburg, MS
    84
    Re: evaporation
    WHEW!!! Looks like you dodged a bullet.
    18x33 Delair Sunsation GS AGP Oval 4 shallow-6 deep mostly buried
