Results 1 to 12 of 12
Thread: Filter losing water to waste
    Noticed the past few days my pool was losing water. As my pac fab fns+ 36 is several years old on original parts, I checked the multiport valve and sure enough, set on filter but water was going out the waste line. I turned everything on and capped the waste outlet until the parts get here.
    I'm need to double check the model numbers but I'm pretty sure my multiport is the model on the right-
    http://www.poolcenter.com/parts_valves_ ... tiport.htm
    As far as I can tell I need to replace the o-ring part #20 (far left schematic) and the gasket part #2, right?
    Will I need any seal or lubricant to install the gasket? This is the correct fix for this issue, right?
    Thanks
    Re: Filter losing water to waste
    #2, the spider gasket, is almost always where the problem is. Only occasionally does #20 need to be replaced. #23 is also a possible issue, as is #21, the spring.
    You need something to scrape the old spider gasket off, often a flat blade screwdriver will work, and something to glue down the new spider gasket, typically super glue. It is also good to have some silicone based pool/plumbers lube to lubricate all of the o-rings/gaskets that you encounter during the process, even if not replacing them.
    It still seems to have good spring tension, but probably best to replace it all once I have it apart. This filter is easily 10+ yrs old, so perhaps it's just a matter of time before they'd need replaced anyway.
    Thanks
    Mar 2007
    Coastalish 'down easter'
    4,160
    I swear I'm not taking your water! :P
    Check the wagon wheel A/K/A spider gasket and the tracks it fits in (as per Jason)
    Luv& Luk
    -Ted
    Thanks waste. Parts are ordered and should arrive soon
    Parts arrived some time ago, but I didn't get a chance to replace the gasket until yesterday. Old gasket was worn, came out easily enough, grooves cleaned up nicely, and installed easily with super glue gel. Gave it several minutes to set, then re-assembled everything. Only problem is it's still losing water to waste
    Took it back apart to make sure the gasket didn't come lose, and it was still seated firmly. I can think of a couple possibilities why-
    1- I didn't lube the spider gasket. I've read conflicting info on doing so and decided not too. Don't know if this alone could cause the problem.
    2- Although I mentioned above that I would go ahead and replace the spring, at the last minute I didn't order the part as it was $20. I thought it was ok, but upon closer inspection it seems like the spring isn't pushing the valve head down on the gasket tightly enough. Not sure if it's the spring or the washers that that transfer the compression force to it when the handle is worked.
    For now I put the cap back on the waste outlet and unless you guys can think of something else I should consider I guess I need to order some more parts
    22,548
    You could try stretching the spring that you have and see if it seals after that. Then you'd know whether that was the problem or not.
    Do you think it's likely got to be the spring or compressing washers? What else could it be? I'd rather know ahead of time and just take it apart once.
    Jun 2007
    New Jersey
    653
    I would also verify handle pin is working smoothly (#18 in diagram). If it binds, the spring may not be able to apply sufficient pressure to the spider gasket. A little PB Blaster may help free it up if it is binding.
    Current: 28,000G 18'x36' I/G AnthonySylvan Plaster; Waterway 60 sq.ft. DE Filter; 1.0hp x 1.65 SF Two-Speed (B2982) WhisperFlo; 2004-Present
    Previous: 40,000G 20'x40' I/G Koven unlined WWII salvage 5/8" marine steel; Lomart Stainless Sand Filter; 3/4hp Hayward SuperPump; 1946-2003 (managed by me from about 1964)
    Ancient Taylor K-2000, upgraded with Taylor CH, TA, and FAS-DPD, and TFT CYA tests.
    Handle moves up and down freely, and I don't feel spring compression through it's entire range.
    22,548
    On my multiport the spring is pretty tight when moving the valve as well as when it seats.
    Thanks. I ordered all the pertinent parts.
