Thread: Intex Pools and Rain Storms
    Apr 2009
    Oklahoma
    51
    Are there any special things that need to be done with an Intex pool during rain storms?
    Should the cover be on or off?
    Should the pump be on or off?
    If it's raining, do you even bother messing with the chemical balance or just wait until the rain stops to adjust?
    We've been having a great time with the pool so far this summer and I just want to take a second to thank everyone for this forum. You all are the reason my pool is so nice and clear!
    32' Doughboy Desert Spring (Blue Bayou liner) Buried with Deep End
    300# Sand Filter, 1.5 HP Pump Hayward
    My Build: making-the-jump-to-a-doughboy-from-our-old-intex-t56425.html
    Crzyfrlss1's Avatar
    Jun 2008
    Central, CT
    161
    Re: Intex Pools and Rain Storms
    Nope, nothing too special anyway.
    Sometimes I'll put the solar cover on, depends on water and air temp mostly.
    Pump is always on, low speed. High speed to skim the surface and vacuum only.
    Most times I dose a little extra chlorine if I know a big storm is coming.
    I wait until the rain stops to check and adjust Ph if needed.
    Intex 15' X 48" metal frame pool
    Waterway Supreme 1hp 2 Speed pump
    Hayward X-Stream 150 Sq. Ft. Cartridge Filter
    2-2'x20' Sungrabber Solar Panels hooked up in parallel on a Goldline GL-235 controller.
    Not getting "Pool Stored" = Priceless!!!
    Thank you TFP
    Jun 2007
    MA
    165
    We just leave it I wait til storm is over text water, so far no issues
    Cheryl
    14X42 Intex Ultra Frame
