Thread: Chlorine smell with balanced pool?
    Isaac-1's Avatar
    SW Louisiana
    6,711
    I am having a higher than expected chlorine smell and eye irritation level, note this is an indoor pool here are my numbers are as of about 2 hours before having 5 people in the pool:
    FC 3.5
    CC less then .5
    pH 7.3 (acid added least weekend dropped to about 7.1 last to reduce TA down from 120-130)
    TA 90
    CYA just under 20
    CH 330 last time tested 2 weeks ago
    Water temp 81
    No chemicals added in the last 2 days (last tested Thursday evening, with FC of 3.0 added .5 gal 5.25% bleach as I knew it would not be checked again until the weekend)
    After everyone finished swimming, I shocked with 3.5 pounds of MPS non-chlorine shock in hope of helping with the chlorine smell, and then added add a couple of tri-chlor pucks to maintain the FC level and bring the CYA back up to 20.
    Any thoughts, am I going the right way?
    thanks Ike
    Re: Chlorine smell with balanced pool?
    You want as much ventilation as you can get. Other than that, it sounds like you are doing everything correctly. Indoor pools tend to have frequent problems with CC. Using MPS is probably the simplest available solution.
    Feb 2008
    Denton, TX
    5,061
    Aside from maybe installing an ozonator which would help some, MPS is the best option.
    Have you looked into ventilation fans?
    Isaac-1's Avatar
    SW Louisiana
    6,711
    The pool is surrounded by 10 sliding glass doors on 3 sides, so natural ventilation is fairly good, 2 or 3 of the doors were open yesterday and there was a slight breeze.
    Ike
    Nov 2009
    Cleona, PA
    236
    For What It's Worth, my outside pool has a higher chlorine smell if I leave the solar cover on for a while. Takes some time to 'vent' away. Normally I haven't had much chlorine smell if any when the cover is off. Yes it's outside and yours is inside, but sounds like just need venting.
    13,500 Wilkes Vinyl AG (15'x30' rectangular)
    Hayward Power-Flo LX SP1580, 1HP
    Hayward S-160T High Rate Sand Filter
