Thread: Help- heating pump location
    Hi guys,
    Thanks for the replies on my cartridge filter questions. I'll go with the larger model.
    Now, I have to decide where to locate a heat pump in the next couple of days. I'll locate it outside with at least 2 feet clearance all sides.
    The questions are; does it have to be in full sun? If not will an overhang roof effect performance negatively? If so how about open above but lattice in front? I don't want to have the thing front and centre if I can avoid it. Also how loud are these things?
    Chris
    Sep 2008
    The Woodlands, Texas, USA
    243
    Re: Help- heating pump location
    As long as you have the 2 ft clearance for air circulation you will be fine. Don't block the air discharge on top!!
    It is just an oversized airconditioner so that is what you can expect for noise (I.e. Maybe not best directly outside a bedroom window).
    IG 24k plaster with overflow spa. Goldline PS-8 SWG. Tristar 0.75 HP filter pump, Polaris 280, large cartridge filter, 400k BTU NG Max-E-Therm HD, SR Smith Turbo Twister, Life Saver pool fence, ORP managed.
