Thread: Upgrading a SuperPump 3/4HP to dual speed
    I have a Hayward 3/4HP Superpump that is starting to get noisy. Since we pay about $0.30/kwh, the two speed pumps looks attractive. Can I upgrade this pump by just replacing the motor and the timer, or should the whole thing be swapped out? The pump is used for a 20k gal chlorine pool with one skimmer, blocked main drain, two returns, and a Hayward EC65 DE filter. All plumbing is 1.5"
    17,000 Gallon plaster pool. Hayward Perflex EC65 DE Filter. 3/4 HP Hayward Superpump converted to dual speed. CircuPool RJ45. Skimmer, floor drain, two returns.
    22,551
    Re: Upgrading a SuperPump 3/4HP to dual speed
    If the wet end is in good shape (i.e. you're not having pumping problems) then it would certainly be worth changing out the motor to a 2-speed. That's exactly what I intend to do as soon as our motor starts giving problems.
    guamguy's Avatar
    Feb 2010
    Guam, USA
    388
    I'm also in the process of this. Right now, I'm trying to find a company that will ship the motor to Guam for a reasonable price. Every quote I've gotten so far, the price of shipping is more than the price of the motor
    12,800 gallon IG plaster kidney-shaped pool, waterslide, 800 gallon spa.
    1HP 2 speed Sta-Rite pool pump, 1.5 HP Sta-Rite spa jet pump. 2 skimmers, 1 main drain
    Purex-Triton TR-60 325 lb.sand filter. 2" Plumbing, Intex SWCG, TF-100 test kit.
    Link to pics of my pool! http://www.troublefreepool.com/my-oasis-t26558.html
    Did this in March w/ a 1 HP Superpump-- was an easy job. Just be sure you understand the wiring for a 2 speed. I used a "canopy toggle switch" on the motor end cap or canopy to manually change speeds, but I think getting a 2-speed timer as you suggest would be very convenient! Good luck-- you'll be glad you upgraded.
    Quote Originally Posted by jparr
    10,000 IG vinyl liner pool, Hayward sand filter, Hayward SuperPump (converted to 2-speed), BBB user
