Thread: A sol'n for backwashin the EC series of DE filters
    May 2009
    Daphne, Alabama
    20
    Folks,
    Have a Hayward EC-65 de filter. Found it quite annoying that I can't backwash the filter like some, and "bumping" the fitler isn't always effective, so I came up with a method to do some quickie backwashing and cut down the need to break open the filter. I cut in a "T" when an elbow used to be just downstream from the filter. Added a female DWV fitting to the open port of the "T". I use a DWV blockoff to close the port when backwashing isn't needed. To adapt a garden hose to do the
    backwashing, I put together a male fitting to match the female fitting in the "T", a bushing to adapt the 1 1/2" pipe size down to a size that fits a garden hose adaptor, added the garden hose adaptor and an adapt to move the hose connector to a horizontal position. I also added a ball valve just downstream from this adaptor, to make sure the water from the hose gets to the filter and there you go, a quickie backwash adaptor for the Hayward EC series of DE filters.
    Steve[attachment=0:35woj83i]BackWash-mods-2.jpg[/attachment:35woj83i]
    [attachment=1:35woj83i]BackWash-mods-1.jpg[/attachment:35woj83i]
    18' x 36' vinyl, 3' shallow - 9' deep
    Hayward Perflex E65
    Hayward Superpump.
    Feb 2010
    Houston, TX
    271
    Re: A sol'n for backwashin the EC series of DE filters
    Nice work! That's thinkin' on your toes right there! I know someone will probably come along and explain why, but I don't understand the point of bumping a DE filter. If it's dirty, and you bump it, it's still dirty! You might be able to redistribute the dirt, but it's still there! I dunno...
    Anyways,
    John
    24' round Vogue AGP 12,000 gal. Flotec AT251001-01 1HP pump, Hayward S310T2 sand filter, Aquarite SWG T-15
    TF-100 (found at TF Test Kits) with Speedstir and Samplesizer
