Thread: sandfilter preasure at max. what to do?
    i was looking at my sandfilter and on the top it, it said "max psi 50".. when i started my pool this year, everything running good, the pressure gage reads 45 psi. when the sandfilter needs to be backwashed it gets to around 53psi. should i worry about my filter exploding, or is this a normal pressure amount?
    p.s. everythimg seems to be running well. filter deatails are in the signature. Thanks for helping!
    24' X 52" round above ground pool---13,500 gallons---Hayward power flow matrix 1.5 hp pump---Hayward 21 in. variflow XL sandfilter---Louisville, Ky
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: sandfilter preasure at max. what to do?
    Your gauge is bad. Get a new one and you should see more realistic numbers. They seldom survive a winter outdoors.
    Aug 2008
    Rochester, NY
    51
    On the advice of someone from this board, I just replaced my 2nd cheap, junk, gauge with a decent Wika liquid filled gauge.
    http://www.gaugestore.com/prodinfo.asp?number=38669
    Decent price at $17 and the gauge seems pretty rock steady with no pulsation or vibration that my cheaper gauges had.
    20000 gal IG freeform, vinyl, Pentair Sand Dollar filter, Pentair 2 speed pump, Pentair Intellitouch controller, Pentair Heat Pump. Built 2008
    Backglass's Avatar
    Jun 2007
    Putnam County, NY
    139
    Quote Originally Posted by jt100
    Great company...fast shipping! I opted for the all stainless steel (inside & out) model. More money, but I only plan on buying one for the next few decades. I also went with the 0-30 model for more granularity.
    http://www.gaugestore.com/prodinfo.asp?number=36506
    wow i will have to check them out. thanks everyone for helping me out. i was freaking out for a second!
    Aug 2008
    Rochester, NY
    51
    Quote Originally Posted by Backglass
    I had contemplated getting the 30 PSI for more accuracy, but since the pentair replacement was 60 PSI and i had no idea what my actual pressure was, i opted for the 60 PSI. I am very happy with purchase so far. It's a nice gauge for a reasonable price. I was also impressed that i ordered it in the afternoon and they shipped it the same day. It arrived a day earlier than i expected too. No affiliation, just good customer service.
