Results 1 to 13 of 13
Thread: DE in the pool--very cloudy
    Shelley N's Avatar
    Denver, Colorado
    199
    I decided to backwash the filter. Even though the psi was only up 2, I hadn't backwashed all summer and I thought it was time. After the backwash and rinse, I added between 1/2 and 1 cup of DE. I watched it come billowing out the return . So now the pool is cloudy. Overnight most of it settled on the bottom, so I got in there today and vacuumed. That was a bugger to do too as it didn't want to leave the bottom of the pool with just the mere sweep of the vacuum as we have a sort of dimpled vinyl bottom so I had to do a sort of "push broom" sweep back and forth to get it up. All that seemed to do was stir it up, as it is cloudy again and doesn't appear to be getting stuck in the filter as planned. It is a 21" sand filter with a 1.5 hp pump. This is just our 2nd season with it. When I hooked everything up in the spring, the sand in the filter looked beautiful, clean and without any veining or crust. We don't get a lot of junk in the pool, just the occasional bug.
    Since it's not clearing, I'm not sure how to clear up the water. It settles over night, I vacuum it into a cloud and we repeat this process daily. Is there a filter pack or something I can put somewhere to catch it? Do I need to stop everything and look into the filter? Ugg.
    Shelley
    Denver, CO
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    You've got a filter problem. Maybe the multiport gasket is bad and not routing all of the incoming water through the sand.
    Shelley N's Avatar
    Denver, Colorado
    199
    Can you tell by looking, or only by the symptom?
    Shelley
    Denver, CO
    SW Indiana
    9,199
    Quote Originally Posted by Shelley N
    You have to disassemble the valve, which isn't big deal. You might just try backwashing again in case something got stuck in the gasket.
    Shelley N's Avatar
    Denver, Colorado
    199
    Well, today makes a week since the DE addition and I've still got the cloud. Every morning there are traces of it on the bottom that the ladybug gobbles up pretty good, but there is still the haze. Is this when you are supposed to use floc? What are the pros/cons to that stuff?
    Thanks all.
    Shelley
    Denver, CO
    Mar 2007
    Coastalish 'down easter'
    4,160
    Shelly, there are times to use a floc and times to wait before doing so. In your present case, I'd hold off on the floc until you open the multiport and make sure that the 'spider gasket' (a/k/a wagon wheel) is in good shape - as per John's suggestion. Ordinarily I'd suspect the filter but you say that you checked the sand recently and it was good, therefore I think John hit the nail on the head and that the multiport is 'bypassing' for some reason. Please make sure that the multiport is functioning correctly before adding a chem which may cause other problems, floc is a last resort.
    Luv& Luk
    -Ted
    Shelley N's Avatar
    Denver, Colorado
    199
    Got it, and thanks all.
    Shelley
    Denver, CO
    Aug 2007
    Northeastern Ohio
    178
    I'm still new to the pool thing, but I thought that sand filters used sand and NOT DE. Are there filters that you put both in?
    ~30000 GAL In-Ground 26'x50' Kidney Shaped Pool
    Hayward EC-75 DE Filter w/1.5HP Hayward SuperPump
    daily user of JasonLion's Poolcalculator
    (12) 2x10 SunGrabber Solar Panels...now if only there was some sun to shine on them!
    SW Indiana
    9,199
    Quote Originally Posted by robrinker
    Some people add a small amount of DE to their sand filters. It appears to make them filter smaller particles, much like a dirty sand filter does. It goes away when you backwash.
    Aug 2007
    Northeastern Ohio
    178
    ah. Thanks for clarifying!
    Shelley N's Avatar
    Denver, Colorado
    199
    Okay, got my DH to help me remove the top of the filter. Looked like the sand we put in, but when you touched it, it reminded me of a layer of lint. Also the sand was 10-12 inches below the top of the filter. I did install the correct sand and the correct amount (200#) last year, but I wasn't around when it was installed, so I'm not sure this is normal depth or not. I did not feel any crust, nor were their any visible holes in the surface indicating a vein, however around the very edge of the sand there seemed to be a different pattern, I'm guessing above where the laterals end. Almost as if it got more flow there and turned the top over so it didn't collect the "lint". We took pictures, but of course the hubby has them in his camera at work. The water on top of the sand was crystal clear, but when we took the drain off at the bottom it was cloudy like that's where the DE was. We put the top back on, backwashed, rinsed and started her up. The gasket spins easily, there wasn't anything stuck anywhere and unless I take it apart, I can't tell if it's doing the cycle it says it's doing. I'm amazed that the manual does not say what each position is as the sticker is suffering in the weather and won't be with us much longer.
    How far from the top of the filter should the sand be? Can this be my problem?
    Shelley
    Denver, CO
    It is normal to have some headroom at the top of a sand filter. There needs to be enough space so that the water flow during backwashing is not enough to wash the sand out the top. The exact height varies from model to model, anything from 6" to 14".
    Houston, Texas, USA
    148
    If the correct amount of sand was put in last year, the "freeboard" (space between top of sand and top of filter) should be ok. The lint you spoke of is normal, and backwashing should remove most of it. The DE "should" get trapped in the filter .... unless you are running the filter in "recycle/recirculate" mode, in which case the water (and the DE) would bypass the sand bed and get blown into the pool. To remove the DE from the filter, backwash then rinse. To get the DE out of the pool, you can do one of two things 1) vacuum while running in "filter" mode to transfer the DE into the filter 2) vacuum to waste.
    Poor Man's Pool
    Doughboy 18 ft round above ground
    7600 gal with center drain
    Pentair sand filter, 1 HP pump
    50 ppm borates
    "I know just enough to be dangerous"
    Pool Calc Ver 1.41 (Excel)
