Results 1 to 8 of 8
Thread: Can't Get Wood Chips to Smoke
    I've tried to get wood chips to smoke on my propane grill twice, both time unsuccessful. Each time, i soaked the wood chips in water and then trained the water. The first time I placed them in an aluminum tray in the corner of the grill where the burner was off. The second time, I put them in an aluminum foil package, poked holes in the package and placed them directly over a flame. What am I doing wrong? Thanks.
    11000 gallon Viking Fiberglass 12 x 28, Intellichlor IC-40 SWG, 24" cascade fountain, 12" cascade fountain, 1 1/2 HP pump, sand filter
    Re: Can't Get Wood Chips to Smoke
    Use the aluminum pan directly on the fire. Dont worry about wetting the chips.
    coloeb,
    20k gal. IG fiberglass/plaster rectangle 32'x16'
    Hayward Superpump 3/4 H.P. primary Hayward model 5060 Booster Pump
    Hayward Pro Series High Rate Sand Filter
    Pentair Model 320 automatic Chlorine/bromine in-line feeder
    Aug 2009
    SW Wisconsin
    518
    to get the chips smoking put them over a high heat area...when I use chips in my grill I put them in some foil, cut slits in the top of the foil and put the grill on HIGH until the chips are smoking good..then I back the heat down to low to cool down a bit before I put the food on.
    33' x 52" Swim and Play Inc. PARAGON AGP. Hayward H200 Heater. Hayward Power-Flo LX 1.5hp pump. Sta-Rite Cristal Flo T-210WF Sand Filter. Stenner 45M5 chlorine pump
    Jul 2010
    IL
    201
    Yes do not wet the chips and if you want to add some moisture add a couple pans of water in the grill. if you want to skip the wood chips all together do a search for the smoke daddy.
    24' AGP Sentinelle 54" , 1hp 2 speed power-flo matrix, New 250K to replace the 150k BTU heater, pool roover Jr. Aqua Trol SWG, Large deck, taylor k-2006, Majestic Stairs with colored LED, COLD BEER
    Aug 2009
    SW Wisconsin
    518
    +1..don't soak the woodchips..just use them dry...wrap them in foil, and put them right on your burner, or oin the heat distribution plate just above your burners..put your grill on high until you see the chips starting to smoke good, then you can adjust your heat back down.
    Also...+1 to the smoke daddy...I just added the 8 inch one to my vertical smoker an I LOVE IT....it produces so much smoke for such a little device. I love it, love it, love it...and I think it was only around $60.00 or so
    Dan
    You can soak the chips but what I do is mix 1 part soaked chips with 1 part dry chips. Wrap in foil, poke holes in top and directly over the flame. I have also used a small metal baking pan or loaf pan and covered with foil as well.... a little more sturdy and reuseable.
    Jan 2010
    Central Valley, CA
    233
    I do soak my chips but only about 15 minutes (because I always forget earlier )
    I have the IR tray that I can drop them in and get exposed directly to the fire. What type grill do you have? would think that definitely makes a difference.
    Garden Leisure Voyager 12x24 AGP, 7500 Gallons, Hayward Power Flo Matrix 1 HP pump, dual speed, Hayward XStream Cartridge Filter, 120 GPM,
    Sep 2009
    Greentown, IN
    914
    I always soak the wood chips but only for a few minutes. I think some of the flavor comes from the steam coming off of them when they get hot.
    I put them in aluminum foil, poke a few holes in it and put in on high heat while I'm warming the grill, I put it down under the grate right above the flames or if I'm using the charcoal grill, right on the hot coals. By the time the grill is good and hot and ready for my meat the wood is usually getting started smoking. Yum
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
