Results 1 to 11 of 11
Thread: Keeping the protective cover on a rolled-up solar cover
    Jun 2007
    Los Angeles, CA
    27
    Anyone got some good tips on keeping a cover on a rolled-up solar cover?
    Our pool is slightly free-form and the deck has a one-step riser near the deep end. Because of that, our solar cover reel (a Rocky's Rollers model) straddles the pool, about 5 feet from the edge of the deep end. It's easier to just keep the reel there, even when we're swimming, unless we're having a lot of people over.
    The only problem is keeping that thin white plastic sheet on top of the rolled-up cover. The slightest breeze picks up the edge and flings it back off of the cover. Since the reel stretches across the water, I can't go around and tuck it in or clip it together. Last season I tried putting binder clips on the edges of the white plastic sheet, which worked OK but left rust marks on the white sheet. Maybe someone else here has a trick that works?
    25k 20x40 oval white plaster with overflow spa
    DE filter
    Aquabot T2
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Keeping the protective cover on a rolled-up solar cover
    We use bungee cords, just stretched all the way around and hooked to themselves.
    mickey4paws's Avatar
    Apr 2009
    S.E. MI
    570
    I use the bungee cords too. Really helps on a windy day.
    IG 12' x 39' - 20k Gallons - Vinyl Lined - StaRite Cristal-Flo II 26" Sand Filter - Hayward SuperPump 1 hp - Dolphin Dynamic autocleaner - Lochinvar Energyrite gas heater - Aqua Rite SWCG T-15 - TF100 Test Kit - Skimlite Duallly 9016 pole (great pole)
    Molson's Avatar
    Apr 2008
    Midland, Ontario
    479
    I will third bungee cords.
    40 x 16 IG Vinyl. Goldline SWG
    160 Sq Ft Roof mounted solar array
    2014 Hydropool Serenity 5000 Hot Tub
    The Pool School- A great place to start
    Jason's Pool calculator
    Jun 2007
    Los Angeles, CA
    27
    Sounds like a solution! Do you just put the bungee cords on at the ends? Because I can't get to the middle of the the reel to put on a bungee unless I'm actually in the water.
    DE filter
    Aquabot T2
    Molson's Avatar
    Apr 2008
    Midland, Ontario
    479
    ends will help, but if the wind is catching it, you'll probably have to put at least one in the middle.
    Nov 2009
    Cleona, PA
    236
    I have some rope I keep near either end of the reel. Just a quick shoe-lace knot seems to hold, even with the windy storms we've been having.
    13,500 Wilkes Vinyl AG (15'x30' rectangular)
    Hayward Power-Flo LX SP1580, 1HP
    Hayward S-160T High Rate Sand Filter
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    I bought a cover for mine that uses velcro on the sides that wrap around the solar cover to hold it on with. Had to buy it separately, because my new solar cover didn't come with the white plastic sheet like my first one did.
    24' x 52" AGP - approx 13,500 gallons
    Pentair Optiflo 1 hp/2sp pump w/ Swimpro Voyager 150 sq ft cartridge filter
    Intex 8110 SWCG
    "Fear the Schnauz!"
    Jan 2009
    Cupertino, CA
    1,966
    I don't actually use the cover cover.
    --paulr
    BBB "Intermediate Swimmer"
    Jun 2007
    Los Angeles, CA
    27
    Paul, since I hate the process of putting a replacement cover on the reel, I'll do whatever I can to keep the current cover in good shape.
    That would mean swimming out to the reel after I've rolled the thing up, since I can't get to the middle from the pool deck. I wonder if I can train the dog to do that?
    DE filter
    Aquabot T2
    Molson's Avatar
    Apr 2008
    Midland, Ontario
    479
    either that or hang a couple weights on the cover mid way.
