Results 1 to 7 of 7
Thread: Trick To Reinstalling My Inground Pool Light?
    OK, this seems like a 5 minute job, but after more than 2 hours of frustration, I'm asking for help.
    I just replaced my the light in my Hayward light assembly and simply can not figure out the 'trick' of matching the top screw into the tiny little hole while under the water. My fingers are too fat to be able to keep in contact with the screw and the hole by the time that the assembly of the light itself requires me to pull my fingers out.
    I have managed to get the little notch at the bottom seated (or at least I think it was) down at the bottom and then attempt to 'lean' the top into place, but simply can't get the screw to take hold.
    I've tried it from the deck, from in the water, with goggles, without goggles, one person, two people. It's full of air...I'm full of air, so nothing's working.
    Surely I'm making this harder than it has to be! I'm about to drain the pool back down to the light to get this done, but surely that's an extreme measure...can someone help me?
    Thanks!
    Gene
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: Trick To Reinstalling My Inground Pool Light?
    Welcome to TFP!!
    I'll bet you were closer than you think
    First make sure the cord doesn't interfere - either wrap it tightly around the light housing or coil it up and shove it all the way back into the niche.
    Then catch the lip on the bottom.
    Then ease the top back to the faceplate. Use your finger to hold the screwhead flush to the rim and just gently move the top of the light back and forth until you feel the screw hit the threads. Start cranking the screw in
    To make it a little easier for you, you can mark the faceplate with a pencil right above the receiving threads.
    HTH
    Luv& Luk
    -Ted
    Jun 2010
    Orlando
    16
    Gene,
    I haven't experienced your specific problem, but I've re-lamped and replaced my light (another story) and if I recall there was a rubber grommet around the screw that held it in place in the light flange so that it would line up with the hole when putting the light back into the niche. You might try fashioning something to slide down over the end of the screw after inserting it into the flange to hold it in place and help with lining it up. Good luck.
    Tiger85
    26' x 13' freeform 10K in-ground w/quartz finish, attached spa, 36" sheer descent waterfall, 2hp sta-rite pump, sta-rite S8M150 cartridge filter, 400K BTU sta-rite natural gas heater and Jandy Aqualink RS-8 controller. Sunny Orlando.
    midtngal's Avatar
    Oct 2007
    Nashville, TN
    496
    Let me throw in my 2 cents worth here on my own light replacement.... after several tries and adult language words, I found that the new screw for the light wasn't as "efficient" (read long enough...) for the "old" housing. When I used the "old" screw...it went in without a hitch. Just something else to think about...may or may not be relevant........... Good luck!
    10,700 gal IG vinyl
    Pentair Triton II TR50 sand filter
    Hayward SharkVac XL cleaner; Emerson 1HP pump
    Bioguard Mineral Springs SWG
    2 skimmers
    CUTiger78's Avatar
    May 2009
    NoVA
    460
    Well, if none of the tricks above work, and if the problem is being able to hold on to the screw, try poking the screw through something that will stabilize it and allow you to hold on to it, like a plastic collar stay, the longer the better.
    (Do I win a prize for today's longest run-on sentence?)
    36K gallon 42X22 gunite/plaster kidney-shaped IG;
    1 hp Hayward Super Pump (new in 2012);
    Hayward S244T sand filter w/ Zeosand (both new in 2009);
    175K BTU LAARS Lite2 LG natural gas heater; Polaris 380;
    TF-100 test kit.
    Mantua, NJ
    80
    I did Ted's steps with one change in bold.
    Quote Originally Posted by waste
    Welcome to TFP!!
    Instead of using your finger, I would use the screwdriver. Have the screwdriver on the screw as you slowly search for the threads. When you find the threads, the screwdriver is already in position to start turning. I still had to move the light a little while turning the screw. Just did this over the weekend.
    Joe
    21k IG vinyl, 300 lb. sand filter, 1hp pump, Polaris 280 cleaner, 3/4hp booster pump, 240sq ft Fafco solar, Liquidator
    Thanks everyone....I finally got it done....
    The advice here is wonderful!
    Next step...convincing the family that we aren't stuck with Baquacil forever. 8
