Thread: The pool in my water is green... no clue what to do
    This is the first time we've opened this pool. We used tap water to fill the pool.
    At first we thought it was algae, so we shocked the pool with Green Out (About 3 times) and used Black Algae Out (Twice). The pool water is still green. We also regulated the Alkalinity and pH to correct levels, no luck.
    Anyone know what's wrong?
    Here's a picture: http://i48.tinypic.com/35lu9gl.jpg
    55 Kilolitre in-ground 18'X36' vinyl lined kidney shape, 1HP pump, Jacuzzi 250lb sand filter, RayPak Delta T 200K BTU natural gas heater. New PoolWerks "Blue Diffusion" liner on May 26th-2011
    Avatar is my pool!
    Apr 2009
    Raleigh, NC
    55
    Re: The pool in my water is green... no clue what to do
    Please post your test results.
    FC=
    TC=
    PH=
    CYA=
    93mastercraft - Aqua Leader Reflexion 21' round 54" high above ground pool. This is not a $399.00 Pool! Wedding cake steps, Haywood 1.5 pump/sand filter. If I'd thought taking care of a pool was this easy, I'd owned one a long time ago!
    Quote Originally Posted by 93mastercraft
    FC=
    TC=
    PH=
    CYA=
    I only own a basic test kit.
    FC - 10 (HIGH)
    pH - 7.2-7.4
    Avatar is my pool!
    Jul 2008
    Sinking Spring, PA
    58
    What type of filter are you using?
    4th Year Pool owner in Sinking Spring PA
    46'x23' Free Form Concrete (34,000 gallons), Aqua Blue Pebble Sheen Finish, Pentair IntelliChlor SWG
    Pentair Intelliflo Variable Speed Pump, Pentair D.E. FNS Filter, Pentair MasterTemp heater.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Green out and Black Algae products won't help you. First, you don't have Black Algae. Second, Green out creates it's own chlorine demand.
    You need chlorine, and lots of it. Shocking the pool begins with knowing your CYA level
    Turning Your Green Swamp Back into a Sparkling Oasis
    Shocking Your Pool
    - so if you don't have the proper test kit you'll need to get one, in the meantime, have your water tested at the pool store, and post the numbers back here so we can help walk you thru the process.
    Test Kit Comparison
