Results 1 to 10 of 10
Thread: MOVING a pool?
    antipode's Avatar
    Jul 2009
    Long Island, NY
    33
    MOVING a pool?
    OK, just an idea we're kicking around...
    We inherited the pool with the house, and realized after a while that the original owners put the pool on the shadiest part of the yard. We're thinking about the feasibility of MOVING it to the other side where there is much more sun.
    Currently, we use the pool for one hour -- then it is so shaded and cool, it's unusable.
    The pool is an AG 24' oval, half buried. The pump and plumbing are all simple and above ground.
    Anyone ever do this? Any idea what the complications or costs might be? Do it myself?
    12'x24' Oval Above Ground (Partially Buried)- 7000 gallons (est.)
    SwimPro Sand Filter
    Current pump: Hayward, 1.5 HP, SF 1, 15 amp (soon to be replaced)
    Western Pennsylvania
    151
    Re: MOVING a pool?
    A heater might be the answer, it would be less work.
    But to move you will need to prep a new area fully dismantle the pool rebuild in new location put in a NEW liner and refill, then use the dirt from the new location to fill in the old one.
    15ft round above ground pool (6600 gallons)
    Sand filter
    Jandy gas heater
    Intermatic timer
    Feb 2010
    Houston, TX
    271
    Re: MOVING a pool?
    With the advice you can get here, you could do it yourself, but it will be a LOT of work! By far the hardest part would be leveling the new site. I'm currently prepping the site for our new (used) pool, and it's backbreaking work doing it by hand. The best advice I can give you is, if you can pay someone to do it, then go that route.
    John
    24' round Vogue AGP 12,000 gal. Flotec AT251001-01 1HP pump, Hayward S310T2 sand filter, Aquarite SWG T-15
    TF-100 (found at TF Test Kits) with Speedstir and Samplesizer
    Re: MOVING a pool?
    Cut some trees down!
    21,000 Gallon Inground Vinyl Sport bottom pool
    Sand Filter
    Casey's Avatar
    SW PA
    10,427
    Re: MOVING a pool?
    Quote Originally Posted by kingjon3rd
    Or move the house.
    It is certainly do-able but a lot of work. With some help from your family and friends, it shouldn't be too much for a DIY'er.
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    Re: MOVING a pool?
    Oh I'm thinking along these lines too - trim some trees, add some solar plumbed from a sunny spot - way easier
    18x33x52 Buttressfree Seaspray (Wilbar) AGP - 1.5hp Pentair Maxim w/22" Pentair Meteor Sand Filter, Aqua Rite SWG System, Biltmore Walk In Steps - 2/4x20 Solar Panel Setup - Doheny Jet Drive (RIP -Pool Rover Jr) - finally hard plumbed the whole darned thing -
    Beats Driving to the Lake!
    antipode's Avatar
    Jul 2009
    Long Island, NY
    33
    Re: MOVING a pool?
    Trim some trees? Move the house?
    With this kind of advice, you kind folks better head over here to help!
    Part of the trouble is that the adjacent lot is a forest (the south and west side). No cutting down gonna happen!
    It hurts my head to figure out why the previous owners put the pool under all of these trees. Literally, from 11:30 to 12:30, we get sun on the pool. (The other side of the yard gets nice sun, all day.)
    A heater is a good idea, but it's not just the temp -- without the sun on the pool, it's kind of dreary.
    So questions:
    -- how hard is "leveling"? (half-buried pool)
    -- must I buy a new liner? it that difficult to install? (expensive?)
    -- does there need to be concrete or metal mesh under the pool?
    -- anyone ever do this kind of work? any idea what the cost might be to have someone do it?
    SwimPro Sand Filter
    dmanb2b's Avatar
    Apr 2009
    NY
    3,731
    Re: MOVING a pool?
    not hard, but a good amount of work and you may need a bobcat
    Yeas, you'll likely need a new liner as the old one will not stretch and becomes dried out when emptied...A new agp liner can be had for for $150-$300
    No, unless suffolk/nassau cty considers a half buried pool an inground pool, which if that is the case you may want to consider not having it buried and will likely reduce your r/e taxes.
    -- anyone ever do this kind of work? any idea what the cost might be to have someone do it? Not personally but we paid an installer $950 for a pretty simple new pool install last year...prices on LI might be a little higher, then add dismantling and the burial...I would guess the cost to be around $2,500-$3k
    Hope that helps...welcome to TFP
    esim13's Avatar
    Oct 2009
    Denham Springs, Louisiana
    320
    Re: MOVING a pool?
    Any idea who put the pool in? Try calling them, or any pool company for that matter, start asking how much they'd charge to put ABG half buried... I'm in Baton Rouge, Louisiana but I can tell you it cost about $6000 to buy and bury mine, 21' round, 3 years ago. I was also told that if I ever drained it, it would collapse in bc of no pressure pushing out on the walls. I would definitly start calling around and asking some questions.
    As for the leveling of new area... My guy came in with a backhoe, started digging (very precisely, I might add) and when he was fairly certain it was close enough he changed to using a mini walk behind bulldozer looking thing. The crew set up the laser level and then they finished the leveling by hand with rakes and such. It was quite a process to watch.
    Hope this helps!
    10,408 gallon, 21' round, 52 in' deep AG, half in ground
    Artesian Clear Master Plus Sand Filter, Artesian Turbo King 2 hp pump, installed June 08
    GEAUX TIGERS!
    Pics taken 2012
    http://i941.photobucket.com/albums/ad25 ... CN0606.jpg
    http://i941.photobucket.com/albums/ad25 ... CN0607.jpg
    esim13's Avatar
    Oct 2009
    320
    Re: MOVING a pool?
    Here's my album of pics, if you're interested.
    http://s941.photobucket.com/albums/ad25 ... ol%202008/
    GEAUX TIGERS!
    Pics taken 2012
