Results 1 to 9 of 9
Thread: Output of gritty substance
    I have an above ground pool ( aprox. 20,000 gal) with a Compu-Pool SWG and a Hayword Sand Filter. The SWG is new to the pool this year. I am having problems with the system outputting a lot of gritty substance I believe to be sand. I did not have this problem until I installed the SWG. Any suggestions as to what is causing this?
    Mike
    25000 gallons kidney shape in-ground plaster pool
    10ft at deep end, diving board
    2 skimmers and 6 return lines
    Hayward DE6020 Pro-Grid 60-Square-Feet Vertical D.E. Pool Filter with 2" Hayward Vari-Flo SP715
    Hayward Super Pump 2hp Sp2615x20
    Hayward 3/4 HP Booster Pump Model 5060
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Output of gritty substance
    Welcome to TFP.
    Could be calcium. Post a complete set of test results for best advice.
    What type of test are you needing?
    Free chlorine = 1ppm, PH = 7.2, Total Alkalinity = 120 ppm, & Cyanuric Acid = 30-50 ppm
    SW Indiana
    9,199
    Quote Originally Posted by migraine
    Calcium Hardness is the key number we need.
    I'll try to get a sample to the local pool supplier this week.
    Okay, went by my local pool supply store and had my water tested here are the results: FAC = 2.5; TAC = 2.5; PH = 7.6; TA = 120; Calcium Hardness = 250; CYA = 50; & Phosphates = 500. I hope this helps. Let me know if there is additional information needed. thanks.
    Mike
    It might be calcium, or it might be sand. There are a couple of different ways of checking. The most reliable is to gather a little of the substance and put a few drops of muriatic acid on it. If it is calcium it will foam up, while sand won't really react at all. Another way to check would be to lower the PH to 7.2. If it goes away at the lower PH then it is calcium.
