Thread: SWG pool
    Apr 2009
    Raleigh, NC
    55
    SWG pool
    Will turning on a SWG after adding Metal remover and stain remover to a pool cause the water to turn green? FC=0 PH=7.2 CYA=0?
    93mastercraft - Aqua Leader Reflexion 21' round 54" high above ground pool. This is not a $399.00 Pool! Wedding cake steps, Haywood 1.5 pump/sand filter. If I'd thought taking care of a pool was this easy, I'd owned one a long time ago!
    Jul 2008
    Sinking Spring, PA
    58
    Re: SWG pool
    I do not think so. Based on your readings your FC is too low. You should add chlorine manually and you probably need to add CYA. Click on the "Pool School" button on the home page. There is a lot if good information there.
    Others will post with better info than I am providing you now, but if you are in a rush to get started then you need chlorine in there immediately. If you want to keep it simple, you could add the bleach now and then add the chlorine that looks like white hockey pucks (dichlor, I think). That will add chlorine and CYA. I would continue with that until the SWG keeps you FC between 3.0 and 5.0.
    4th Year Pool owner in Sinking Spring PA
    46'x23' Free Form Concrete (34,000 gallons), Aqua Blue Pebble Sheen Finish, Pentair IntelliChlor SWG
    Pentair Intelliflo Variable Speed Pump, Pentair D.E. FNS Filter, Pentair MasterTemp heater.
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    Re: SWG pool
    Adding chlorine in any form when you have metals in the water will cause discoloration - sometimes yellow, brown or greenish blue. However, if you have metals and have used appropriate amounts of sequesterant will not cause the discoloration - NOT having them will.
    You need to get your CYA up there to an appropriate amount for a SWG pool (usually around 70) and your FC at about 2-4ppm. I'm thinking your PH may be hanging right on the edge of low - perhaps watch that, but since SWG usually result in PH drifting upwards you may be OK - just keeping an eye on it. Now, you can start off with some pucks or bags of the pool store powders (not Cal Hypo - no CYA there) if that is all you have around but the best route is the granular CYA in a sock in front of the skimmer and bleach. People with pucks and powders feel like they are obligated to use them since they paid for them and often don't carefully watch the CYA levels - which can take up to a week to register, depending on different conditions so by the time they know what they have - it can be too late and only fixable by draining. Carefully measuring amounts for your pool volume is really the best way to get what you need and be confident that you are where you need to be.
    18x33x52 Buttressfree Seaspray (Wilbar) AGP - 1.5hp Pentair Maxim w/22" Pentair Meteor Sand Filter, Aqua Rite SWG System, Biltmore Walk In Steps - 2/4x20 Solar Panel Setup - Doheny Jet Drive (RIP -Pool Rover Jr) - finally hard plumbed the whole darned thing -
    Beats Driving to the Lake!
