Thread: First test results
    Jul 2007
    Rockville, CA
    99
    First test results
    Here are my initial test results. What do I act on first?
    FC: 4.0
    CC: 0
    Ph: 7.8
    TA: 80
    CH: 400
    CYA: 30
    Temp: 71
    Salt: 3200
    My gut says to adress the CYA as the manufacturer's suggested range is 60-80 ppm. While the CH is at the high end of the ideal range proposed by AquaLogic/ Goldline (200-400 ppm), I have some landscaping dirt blowing into the pool that may be causing the elevated number. The calculator indicates nearly five pounds of cyanuric acid. Can I pour this into the skimmer basket even though I use a cartridge filter? What other parameters are likely to change as a result of increasing the CYA? Where do I go first? Also, as I am transitioning from having a pool service (he shows up on Fridays, dumps in some muriatic acid and leaves, uh exits) should I wait until after he does his thing on Friday since it takes a week for the CYA to dissolve?
    20K inground gunite w/ Aqua Logic automation and chlorination Sta-Rite 400 K natural gas heater and cartridge filter 2 HP pump 1.5 HP spa bubbler for spillover spa 1 HP dedicated Letro Legend cleaner
    H2O: two parts Heart and one part Obsession. ~Author Unknown
    Put the cya in a sock and hang in from a ladder, or put it in the skimmer.
    I would lower the pH a smidge.
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
    The CH level shouldn't be a problem unless it goes up.
    CYA in a cartridge filter is fine. However, if you put the CYA in the skimmer it is important to not clean the filter for a week. That is why the sock approach The Mermaid Queen suggested is popular, no need to worry about the filter at all.
    Jul 2007
    Rockville, CA
    99
    I got the pH down to 7.4. As far as the sock goes, do you mean a regular athletic sock or is there a special pool sock? Sheesh.
    Quote Originally Posted by flintstone
    a tube sock would be fine... a knee high stocking would also work.
