Thread: Autofill valve leaking
    I have an autofill valve that is constantly running. Its a toilet float type.
    The leak is around where the brass/metal valve is encased by the plastic/rubber grommet type fitting. Any ideas on how to repair?
    Thanks
    Blessed is the man who can laugh at himself for he will never cease to be amused.
    To teach is to learn twice.
    My Pool. 20 x 40 120,000 litres (about 30k gal) sand filter, a pump of some type...lol & a bunch of neighbourhood kids.
    Re: Autofill valve leaking
    Welcome to TFP!
    It is tricky to diagnose without seeing it, but I cna think of two common possibilities. Most like it is leaking around the threaded fitting where the brass valve is screwed into the plastic fitting. If so, you can remove it, clean the threads, apply pipe dope, and re-install. Another possibility is that the plastic fitting is cracked, in which case the plastic fitting will need to be replaced.
    Here is a pic. The leak can be seen by my finger where the metal valve meets the plastic fitting. The plastic fitting does not appear to have any cracks.
    So the metal valve actually screws out? I tried but it wouldn't budge.
    22,539
    The metal valve should screw out of the plastic fitting. Looks like it's got some teflon tape on it so you may get by with removing it, cleaning it up and either using paste or t-tape again and screwing it back in. Be sure to inspect the brass piece to make sure it isn't cracked.
    You are correct, I removed the valve and the threading had been stripped in a couple of areas (who knows how, maybe at install or pre-install). I managed to apply enough teflon tape to stop the leak now, and have ordered a replacement valve from the manufacturer.
    Thanks for the replies.
