Thread: Cloudy Water - Levels OK
    Jul 2008
    austin, tx
    9
    Hi everyone,
    So after a partial drain a few months ago due to high CYA and high CH levels, I switched to the BBB method. Everything has been great, water has been perfect. The partial drain didn't help my CYA levels too much, so I've had to maintain a pretty high FC level. Earlier this week I went outside and my water was pretty cloudy! I checked my FC level and it was at a good level. I then shocked it thinking somehow a small algae bloom might have snuck in. Since then the cloudiness has reduced a bit, but it's still there. Two things: 1) I lost a skimmer sock down the drain a few days before the cloudiness started and 2) a big rainstorm came through the night before the cloudiness started.
    I can see how the rain might have caused it, and the cloudiness is just dirt? But any chance the lost skimmer sock could be affecting things?
    thanks!
    15,000 Gal IG Plaster
    Hayward Sand Filter
    Hayward 1.0 HP Pump
    Hayward H Series Heater
    Really OLD Polaris Pool Cleaner
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Cloudy Water - Levels OK
    Test results, please
    You might want to open up that filter and find that sock...
