Thread: Salt too high
    May 2009
    Trenton NJ
    497
    Salt too high
    My swg runs optimum at 4000, my salt level is 5320. How do you you get it lower? I would rather not drain water because my cya is only 50,and I need to bring that up.
    What should I do. I do not want to damage my equip. with a salt level too high.
    20,000 gallon viking fiberglass pool w/aqua comfort heat pump, pentair whisperflo pump 1.5hp autopilot dig-220 swg w/RC42 cell (42,000), pg2000 fiber optic lights
    hayward sand filter(medium is echoglass)
    Blue diamond robot cleaner
    Re: Salt too high
    There are only two ways to get the salt level down, replace water and a reverse osmosis treatment. Check your SWG manual to see how high it can have the salt level and still work. You probably won't need to replace all that much water.
    May 2009
    Trenton NJ
    497
    Re: Salt too high
    It said in the manual not to exceed a salt level of 13000ppm, it will damage the electronics. So i guess I am safe there. How about the pump and I also have a heat pump, could it do any damage to them?
    May 2009
    Trenton NJ
    497
    Re: Salt too high
    One more thing my fc is 6.5 so I lowered the output on the control board
    Re: Salt too high
    As long as your Salt level is below 6000 there isn't any significant risk to the pool. The risk of corrosion from salt rises very slowly as the salt level goes up to about 6000. Over 6000 it rises much more quickly.
    May 2009
    Trenton NJ
    497
    Re: Salt too high
    Thank you, I need to add water today so that should help a bit.
