Thread: gas smell when heater cycles on
    I have a Pentair heater on our spa, and when it cycles on I can smell gas briefly as it fires up each time it cycles on. I Had a the pool company send a the repair guy out, he checked everyhting and said it all check out fine....and it is "normal" to smell a little gas when it ignites. Is this in fact normal, or something to be concerned about?
    GM
    ~45' x 15' free form (9.5ft deep end) pool; Pentair 4 speed pump w/ JetVac cleaner & booster pump; DE FNS 60 filter; Intellichlor SWG; Diamondbrite finish.
    Re: gas smell when heater cycles on
    Its normal.
    coloeb,
    20k gal. IG fiberglass/plaster rectangle 32'x16'
    Hayward Superpump 3/4 H.P. primary Hayward model 5060 Booster Pump
    Hayward Pro Series High Rate Sand Filter
    Pentair Model 320 automatic Chlorine/bromine in-line feeder
