Thread: Artificial waterfall
    rrc1962's Avatar
    Jun 2010
    Nashville, TN
    23
    I'd like to put in a small artificial stone waterfall. If would be on the deck covering the area that is cutout for the skimmer. Look in the lower left of my avatar. It needs to be light weight so it can be easily slid aside to deal with the skimmer. Either that or I'll need to build in an access door. Can anyone suggest some ideas? I'm a little lost as far as building one and everything I've seen online is hideously expensive...like in the thousands. I just need something made out of fiberglass or plastic, 3 or 4 feet long and a couple feet wide that looks like a rock formation. It doesn't even have to be plumbed. I can add plumbing to get the effect I want. It would sit on the deck and hang over the pool edge.
    24' Above Ground
    1.5HP Waterway Pump
    Hayward 120sq/ft Canister Filter
    Soon to be abandoned AquaSmart system in favor of the BBB system.
    Re: Artificial waterfall
    Interfab makes some fiberglass artificial rock waterfalls in different sizes and price points.
    http://www.interfab.com/Waterfalls/Page/734/Show.aspx
    You can find the prices on eBay.
    18' x 36' Vinyl Kidney 24,000 gallons
    Soon to have Salwater system up and running.
    Intelliflo pump, Colorlogic LED Light and a lot less money in the bank
    Guest
    Check the website and see if any of these would be light enough or work for your application: http://www.ricorock.com/
    rrc1962's Avatar
    Jun 2010
    Nashville, TN
    23
    Thanks...I found some on eBay that would work, but this morning I saw a pool with wood deck with a stone water feature and it looked sort of out of place. I'm rethinking now. I may just build a sitting bench with a waterfall underneath. Wife wants something like this, which I can build from wood.
    http://cgi.ebay.com/Manor-House-Scupper ... 9520425914
    24' Above Ground
    1.5HP Waterway Pump
