Results 1 to 17 of 17
Thread: Chlorine burning off Slowwwwwly
    My CYA is 75. Yes, I know it's high and this causes chlorine to burn off more slowly, correct?
    I just want to make sure about this b/c between yesterday and today, my FC went down by only .5ppm (form 15.5 to 15). This just seems a little slow. The previous day, it had gone from 17.5 to 15.5 - but we also had rain during that 24 hour period.
    I realize that the chlorine will burn off eventually, but I'm just impatient b/c we will be using the pool throughout the weekend.
    TFP SUPPORTER through TFTestKits.com - My Pool: South Florida, 11K gallons, In ground, concrete / Diamond Brite, Free Form with attached spa (no heater- go figure) Built around 1998, original surface, Jacuzzi Magnum Force 1.5HP pump, Jacuzzi Cartridge Filter, Rainbow 320 Tablet Feeder, Hayward Navigator Pro, Taylor K-2006 w/ TFTestKits replacemeng Reagents.
    22,553
    Re: Chlorine burning off Slowwwwwly
    Is the dial on your feeder on zero. Even if it is it could leak a little through it. With a CYA of 75 you're safe to swim with it at 15.
    Yeah, I'm thinking there's probably a trickle coming through with the feeder, but it is set at zero.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Swim! That level is fine and harmless with a CYA of 75
    Quote Originally Posted by frustratedpoolmom
    No doubt, I just got out of the pool and it was . Could have been a little less chloreeny but nothing worth staying out of the pool for.
    30,431
    I'm curious about that. Tell me what it was that made it "chloreeny"
    poolgirl22's Avatar
    Apr 2010
    Stephens City, VA
    595
    No kidding...we were swimming last week at 22-24 with CYA 55...no ill effects whatsoever...we swam almost the entire time I was shocking...causes a little backward progress but...we only have 4 months so...
    As long as it is clear and not excessive CCs, we swim. So...if you were feeling 'chloreeny'...there may be something going on.
    Edit: I hadn't read the ^ post until after I mentioned CCs....
    Backyard pool-less, but used to be.....
    16,100 gallon, 18x38 3.5 ft deep oval AG, Vinyl, Sand, 1hp pump
    http://www.poolservicestech.com Liquidator
    http://www.poolcalculator.com/
    http://www.tftestkits.net TFT100 test kit
    There's a certain smell & taste of the water when the chlorine is a little high. And also, the skin dryness is a little more when you get out of the water.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    Quote Originally Posted by niceguymr
    Curious. I've been in my pool with FC higher than that (CYA also higher) and can't smell anything. Nor does my skin feel dry or itchy afterwards. Hair, what's left of it, doesn't feel straw-like when it dries.
    Now for the TFP Mantra: Can you post a full set of test results?
    11,969
    Yeah, that smell is prob CCs... how high were they when you did the aforementioned testing?
    30,431
    Like Richard, I have had my pool in very high FC conditions with no detectable differences from normal. Postiong a full set of test results will be helpful.
    11,969
    Me too...never had drier skin or smell/taste.
    Quote Originally Posted by Richard320
    FC - 15
    CC - .5
    PH - 7.5
    TA - 90
    CH - 260
    CYA - 75
    That was taken yesterday immediately after I went for a swim. (The CYA was tested a few days ago)
    11,969
    Hmmm. They look good!
    I don't see anything to indicate why you would have a chlorine smell. Maybe you are more sensitive to it then me?
    That's kinda what I was thinking. I'm going to retest everything again today just to make sure my results are consistent.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    For what it's worth, I can smell chlorine on my skin after swimming at high FC (higher than normal, but not shock level). Not a CC smell; it smells just like bleach. I guess niceguymr and I have much sharper senses than the rest of you chumps!
    Mar 2007
    San Rafael, CA USA
    12,082
    If you sweat a reasonable amount, then at higher chlorine levels you can smell CC on your skin and that's monochloramine. If you don't sweat much, then you can sometimes smell the FC which smells like bleach.
    The odor threshold for smelling chlorine in the air above the water is roughly an FC that is around 25% of the CYA level. For monochloramine, it's a CC level of around 0.6 ppm. On skin, evaporation will remove the water increasing the concentration of what is left so some people can smell chlorine on their skin even if the chlorine level in the pool is very low.
