Results 1 to 9 of 9
Thread: Autofill question
    Autofill question
    Hello, my pool water level has dropped 1"-1 1/2" from normal, as indicated by the 'normal' calcium ring around the tiles. I was instructed to turn my autofill "nut" counterclockwise to reset and fill the pool. Is this correct, how does the autofill work? Oh and I cannot seem to turn the nut it is on very tight. The pool was recently re-plastered so I doubt it is due to any leaks. Thanks for any help. I'm a pool newbie.
    35,000 gal. Plaster, in-ground, Hayward swimclear C4025 cartridge filter,
    5 port polaris cleaning system, Hayward gas heater, spa.
    PhoeniX, AZ
    22,548
    Re: Autofill question
    That sounds like a "toilet float" type autofill. If so then they probably told you correctly. If it's not then post a pic of it and we can give better advice.
    Yeah, i think you are right, but how fast should it fill/correct itself. I was told I could flood my whole backyard if I was not careful. I last adjusted ~2hours and no change is visible, but like I said the nut is really tight. How do I know if its working?
    PhoeniX, AZ
    22,548
    It should be pretty slow once close to full. Did they turn off a valve in the line to it somewhere?
    If you push the float down does the water flow from it?
    I think it's open, if you push down the float water does flow. is the nut supposed to be REALLY tight and hard to turn?
    PhoeniX, AZ
    22,548
    Some them are really hard to turn and some of them have a jam nut that you need to loosen before you can turn the main one.
    The person I talked with called it a "flip-n-float" not sure if that is a brand name but it has a cylindrical white floater. Mine has a wing nut that I am assuming I need to turn more to the left, but when I try to adjust I cannot tell if it moved and the pool is definitely not filling at this point. I am concerned only because the water is about 1/4 of the way up the skimmer inflow, and I know it needs to be/should be 1/2 the way up. Not sucking air yet but am trying to avoid that problem.
    PhoeniX, AZ
    22,548
    The flip-n-float is a toilet float. You lossen the arm bolt and adjust the float up or down. Does it look like this?
    If it does you can just bend the arm up a little to adjust it. Be careful not to bend it too much.
    Ok so it's ben a while since I adjusted the arm, bent it up a little. the pool was so slow to fill and last night the overfill area was ---overfilling! So I adjusted the arm down and the water level has receded in the overfill area. I am imagining I have a clog or some debris in the line into the pool. I will try to check this out today, but still have the problem of filling the pool back up. Just wanted to say thanks for your help and keep you posted on the new development, lol.
    PhoeniX, AZ
