Results 1 to 9 of 9
Thread: Vaccuming with sock on? Pics added.
    bwiley47's Avatar
    Princeton, WV
    97
    Saw a recent post where someone suggested using a skimmer sock on your vaccum to get up sand/pollen on floor of pool. My water is clear but I am unable to get what I believe to be pollen up. Pollen has been horrible this year. I have been sweeping it to stir it up and using a skimmer sock, but it is very slow going. Any suggestions. Hopefully I remember from last yr how to upload pics from photo bucket.
    This is my water
    The thorn in my side.
    Water does not look green.
    Here is my vaccum. Any suggestions are appreciated.
    Will try pics again. See it didn't work. Yea!! I did it.
    16 x 32 AG Fanta Sea 13,500 gal/ Hayward Sand Filter/ 1 hp Hayward Power Flo LX Pump
    1 skimmer 1 main drain
    Feb 2008
    Denton, TX
    5,061
    Re: Vaccuming with sock on? Pics added.
    I don't really have any suggestions other than to keep at it. If it is pollen, then the problem is that it will continue to deposit in your water despite all your efforts to rid the pool of it until all of the pollinating suspects quit pollinating. I would also try to be pretty vigilant about covering your pool when you aren't in it.
    22,543
    I think a fine skimmer sock would definitely help your situation. You have to be careful when using a sock vacuuming fine particles because it will clog fairly quickly. Just keep an eye on the suction of the vac and you'll know when it needs emptying.
    bwiley47's Avatar
    Princeton, WV
    97
    I guess I should have asked how do I vaccum with a fine sock. Pull it over the vaccum place a secure it someway? Then the particles are pulled into the vaccum and caught by the sock?
    Problem is we don't have any type cover. If I could at least find a way to get it out I would not care about any up keep.
    Bonnie
    22,543
    Do you vacuum using a vacuum plate in the skimmer or do you have a dedicated vacuum port?
    If you have a vacuum port you'll need to get a leaf canister with a fine sock that goes inline with the vacuum hose.
    If you use a skimmer plate you just leave the skimmer basket inplace and put a sock over it.
    bwiley47's Avatar
    Princeton, WV
    97
    We usually just pull the skimmer basket out and hook directly in, but didn't think about using the skimmer sock in the actual skimmer and then the plate!! Thanks I will try it!!
    22,543
    It's better to use the plate so you can leave the basket in place so it can catch the stuff an keep the pump basket form having to do it.
    Jul 2010
    Grass Creek, Indiana
    1
    Take it for what it is worth from a two week pool owner , but due to the high number of trees around my pool, the installer recommended panty hose over the skimmer basket to catch particles from the trees naked to the human eye and skimmer basket.
    27ft 54in Aqua Leader
    2 hp Hayward pump w/ cartridge filter
    Western Pennsylvania
    151
    I have been using skimmer socks for about a month now, I have not needed to bump my filter since i out them in, it surprising how much brown gook the sock catches.
    15ft round above ground pool (6600 gallons)
    Sand filter
    Jandy gas heater
    Intermatic timer
