Thread: multi-port filter valve chattering......
    Nov 2009
    Fort Gibson, OK
    7
    I have a friend with a jacuzzi filter with the multi-port valve on top of the filter for an above ground pool, that has been chattering occasionally. It seems to stop after a backwash, although the pressure before the backwash may not be necessarily all that high.
    Any ideas on what might be happening here? He says he taken it apart a few years ago to repair a leak on the backwash port, but it has been working fine until this season.
    30K gal, 20x40 grecian, vinyl, inground. 1 1/2 hp hayward super pump II, Sta-rite sand filter.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: multi-port filter valve chattering......
    Air is the most likely cause of a noisy multiport. Is there air in the pump strainer housing?
    Nov 2009
    Fort Gibson, OK
    7
    No air
    22,542
    Could be a weak spring that allows the gate to rattle. It would get worse with a pressure increase. Might be worth rebuilding.
    Nov 2009
    Fort Gibson, OK
    7
    Thanks.....that's what I'll recommend
