Thread: SWG T-15 not working
    I was told the T-15 was bad it was not reading any salt than would read 2200.
    We recieved the new SWG the service light is still on and the salt reads 0000.
    No they are saying we need a new circuit board if the circuit board was bad why would it read any thing.
    how do I reset the trouble light?
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: SWG T-15 not working
    Which controller do you have? For the Aqualogic, you can go to the diagnostic menu, click right then click + buttons.
    Mark
    Guest
    If its the Aqua-Rite, Push and hold diagnostic button. Have you recalibrated your board? Push diagnostic button until you get to instant salinity (as per manual) and move the (Off, Auto, Superchlorinate Button) up to Super Chlorinate and back to Auto. See if that works first!
    Sounds like mine and it was the board. Seems the most common is the frying of the board electornics. I think there may even be a couple threads on here about this...
    http://idoneitmyself.wordpress.com/2009 ... lightning/
    South Florida. 20,000 gallons; 16x35 rectangular gunite; Pentair Intelliflo VF Variable Speed Pump; Hayward cartridge; Aqua Rite SWG. Dolphin Oasis Z5 Robotic Pool Cleaner; Kopec 540sc Electric Heat pump pool heater; Pool built in Spring 2004.
    Mar 2009
    Huntsville, AL
    156
    There is also this link that talks about a repair to the circuit board, but I think it may be a different error code than what you are getting:
    http://www.nocellpower.com/
    27K gal, IG vinyl, 1.5 HP pump, 24" sand filter, Goldline Aqua Plus SWG
