Results 1 to 11 of 11
Thread: what do u all. think about this pump
    I'm wanting to replave cheap. Pump that came with my intex easy set 18 x 48. Wqould this be a good one.
    http://louisville.craigslist.org/for/1729949158.html
    Intex Easy set 18x48 pool
    Intex Sand Filter
    Intex SWG system
    TF100 test kit
    Crzyfrlss1's Avatar
    Jun 2008
    Central, CT
    161
    Re: what do u all. think about this pump
    That's a good deal go get it before someone else gets it.
    Intex 15' X 48" metal frame pool
    Waterway Supreme 1hp 2 Speed pump
    Hayward X-Stream 150 Sq. Ft. Cartridge Filter
    2-2'x20' Sungrabber Solar Panels hooked up in parallel on a Goldline GL-235 controller.
    Not getting "Pool Stored" = Priceless!!!
    Thank you TFP
    Looks pretty good to me to start with. I was running a Hayward 180T (150lb sand filter) and 1HP pump and it was much better than the crummy intex pump we had.
    I paid $100 for mine as well but it had no base plate or hoses.
    Greg
    27' x 52" Round Lomart Sandstone AGP
    ~ 18,000 Gallons
    Hayward S244T Sand Filter 300lb
    Hayward 1HP Matrix 2 Speed pump
    2" Plumbing - 50 Foot run buried 18" Deep - Widemouth skimmer and 1 return with eyeball
    Compupool CPSC24
    they may have sold it. no reply so far. would i need anything else to hook it up to my intex pool.
    Intex Sand Filter
    Intex SWG system
    TF100 test kit
    here is one that seems good but maybe overkill but i could use it later on if I get a bigger pool. http://cgi.ebay.com/1-5-HP-Above-Ground ... 439e4a47d4
    What do you all think of this one. about 100 dollars more than the inex sand filter.
    Intex Sand Filter
    Intex SWG system
    TF100 test kit
    mcoonan's Avatar
    Aug 2008
    Mendota Heights, MN
    292
    If you still want to look at Craigslist, try using www.searchtempest.com It allows you to look beyond your local area and sometimes the best deals are worth the drive.
    Intex Ultra 18' x 52" AG 6,981 Gal.
    3 - 2'x20' solar panels
    Hayward XStream 1500 Cart Filter
    Hayward 1-1/2 HP 2-speed Superpump
    Aquabot Pool Rover
    2-Softub 300 hot tubs (yup just got one for the lake)
    TF Test Kit Doing the BBB for 7 years
    Medota Heights,Minnesota
    I have tried that search way. But not having much luck. Everytime I find something its gone or I get no reply. Also I'm not two sure what all I will need to hook it all up to easy set pool
    Intex Sand Filter
    Intex SWG system
    TF100 test kit
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Quote Originally Posted by pitmanr2003
    Pump is too big for a 200lb sand filter
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Unprecedented vaule! Visiable pressure gauge! Advanced impeler design! How hard is it to spell-check an eBay auction?
    I agree w/ dman; the pump is way to big. Really, it's too big for just about any residential pool.
    im having hard time finding them on craigs list and have used tempest. Im not sure really what to look for being Im a newbie. when I do find a good deal its either already sold or I get no answer so I assume it is already gone. Also Im not sure how hard it will be to hook up to my existing setup. Thats Why I was thinking of just going with the intex sand filter. Its a direct bolt on.
    Intex Sand Filter
    Intex SWG system
    TF100 test kit
    jsf0656's Avatar
    Apr 2010
    south georgia
    313
    this is what i'm thinking about doing. seems like it being a straight hookup
    is the way to go. plus the intex sand filter is getting great reviews on amazon! i know its only been out a short time but so far the ratings are 5 STAR!
    18x52'' intex AGP, 6981 gal, 2650 intex sand filter,
    thru wall skimmer, SWG, 52'' 20G overlap liner, intex pool light
