Thread: Where do I start correcting these SWG readings?
    CYA - Too low to register
    TA - Too low to register
    pH - 7.98
    FC - Too low to register
    TC - 0.19
    Finally got a tester for our newly inherited pool and the readings are as above. What should I start by altering? I think pH, then TA and CYA but just wanted to check. Would I do chlorine levels last of all?
    Thanks from a newbie who is very glad she has a tester now!
    176000
    Sand Filter
    Above Ground, Vinyl
    1.5 hp Hayward Power Flo LX Pump
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,409
    Re: Where do I start correcting these SWG readings?
    Hi, what are you using to test with? If these are readings from an electronic device I would not trust these results. Unless you filled your pool with distilled water it would be very unusual to have nothing in it. Also we need to know your CH (calcium) level, pool size and type in order to make recommendations for your pool.
    Love TFP? Become a
    TFP Supporter!
