Thread: Penter IntelliFlo and automation of pumps and draining
    CA
    3
    Hello all. I am looking for some advice regarding the Pentair IntelliFlo pumps and SunTouch. Is the SunTouch able to ramp up the speed of the VS 3050 pump during the middle of a cycle? Say it is running 1000 RPM, can the SunTouch bump it up to 1500 RPM for a set amount of time and then back down to 1000 RPM? Are there automation systems by other manufacturers that can do this?
    I am also curious what solutions there are for automated pool draining. I don't need the automation to decide when to drain, I would just like to be able to press a button from inside the house during rainy season to start and stop the draining. There is a currently a hose bib which has to be manually opened to start draining. It is a real pain, especially when it is pouring and muddy. I am wondering an electric sprinkler valve would do the trick.
    Any help is much appreciated.
    20,000 gallons. 1HP Hayward. 280 Polaris with booster. Hayward cartridge filter. 1 1/2HP Hayward to run waterfall/heater and who knows what else it is hooked to. Still learning what all the valves control. :(
    Guest
    Re: Penter IntelliFlo and automation of pumps and draining
    Quote Originally Posted by MikeGyver
    Rainy season? You're in California, man! We don't have a rainy season! You're blowing the illusion of 365 days of sunshine, sandy beaches, palm trees and balmy breezes!
    Next you'll tell me Santa Claus isn't real
    Jun 2010
    Fremont, CA
    293
    I'm somewhat curious about what the SunTouch control can do with the VS3050 also, like Mike's question above.
    Can the SunTouch control run the Intelliflo VS at 1000rpm for a period. Then run it at 1500 for another period?
    40 x 16 (28k gallon) plaster pool, Intelliflo VF pump, Hayward 48 sq. ft. DE filter, using Purifiber, using BBB, TF-100 test kit
    Yes, the SunTouch can change the speed. Speeds are associated with circuits, so for example the pump can change speed any time AUX1 is on.
