Thread: Switching to bleach this weekend
    Apr 2010
    Buckeye, AZ 85326
    619
    We are having a mess load of people/kids over for the UFC fight this Saturday. My floater is just about empty and I have 4+ gallons of 6% bleach on standby. CYA has slowly climbed *just like you all said it would* to what I think is a good level.
    My current numbers
    FC 5
    TC 5
    CC 0
    pH 7.6
    TA 100
    CH 200
    CYA 65ish
    I've been using the aerator at night to keep a few degrees knocked of the temp of the pool but it doesnt seem to affect anything .......yet
    Thanks as allways for all the help and this saweeeet website!
    11,872 Gallon IG Shotcrete play pool
    Blue Granite Pebble Sheen finish
    Hayward SwimClear c4025, Navigator & Tristar 1.75hp pump
    2' Powerfall
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Re: Switching to bleach this weekend
    Welcome
    FC = 5 is your minimum. You should Target 10 when you add chlorine so it is still over 5 the next day when you add chlorine again.
    With your TA is a little high, coupled with the fact that you are now using bleach, your pH will tend to drift up. Regular additions of muriatic acid to keep your pH in check will eventually bring your TA down pH will become more stable.
    CH is a little low.
    CYA is high, but not unmanageable.
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
