Thread: hello from walnut creek
    Just wanted to say hello. I am planning upgrades in the near future to hopefully lower my cost of ownership, and also gain convenience and functionality.
    My initial move is to replace my single speed 1.5hp pump with a vs 3050.
    32,000 gallons, gunite, 4 jet spa, 1.5 hp hayward pump, 60 sqft DE filter, polaris 280, 3/4 hp booster,
    TL 300,000 gas heater, 2" return, 2" suction (reduced to 1.5" supply/exit of heater)
    Apr 2010
    Buckeye, AZ 85326
    619
    Re: hello from walnut creek
    Welcome....you have came to the right place.
    11,872 Gallon IG Shotcrete play pool
    Blue Granite Pebble Sheen finish
    Hayward SwimClear c4025, Navigator & Tristar 1.75hp pump
    2' Powerfall
    Thanks!
    My initial calculation shows me at around $500 per year in electrical savings. $1000.00 for the pump is a no brainer. I plan to post in the pump central forum!
    Feb 2008
    Denton, TX
    5,061
    Welcome to TFP!
    Butterfly's Avatar
    South Carolina
    10,045
    Welcome to the forum
    You're done SLAMing when:
