Results 1 to 7 of 7
Thread: Orange-brown stains on the bottom of the deep end
    DLO's Avatar
    May 2008
    Sioux City, IA
    47
    I have the same colored stains in the deepend. They tested negative with the Vit C tabs. Now what?
    "Beer is proof God loves us and wants us to be happy." -B. Franklin
    In-ground, vinyl lined, 20'x40', 3-10' deep, solar heater, sand filter, 3/4hp pump, Dolphin Pro, Cover Star Auto Cover.
    A proud BBB convert.
    DLO's Avatar
    May 2008
    Sioux City, IA
    47
    Re: Orange-brown stains on the bottom of the deep end
    Disregard my previous post, I let the tablets sit on the stain for about 15 min, didn't see any reaction. Took the kids swimming and looked after about 30 more min...the stain was completely gone where the tabs were. The stains only take up an area of about 2sq/ft. I'm just going to spot treat the stains with Vit C tabs under clingwrap and some weight around the edge of the clingwrap. can't see treating the whole 40k gal for a few spots.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    DLO, putting the Vitamin C tabs in a sock may work and be easier to handle. If you try the clingwrap, let us know if it works! New tricks are always worth hearing and passing along to the next folks...
    DLO's Avatar
    May 2008
    Sioux City, IA
    47
    A sock. Another great idea MITS....maybe a hybrid of the two; sock under the plastic wrap to retard the ascorbic acid being dissolved and carried away tward the pool water. I'll try to put the tabs in a sock, cover it with plastic wrap, cover the perimeter with my dry suit ankle weights. I'll let you know how it works. (Kind of makes me want to buy a submersible case for my video camera )
    DLO's Avatar
    May 2008
    Sioux City, IA
    47
    Here's what I'm going to use. I commandeered a pair of hose from the wife, being smart enough to leave the thigh highs in pristine condition . Cut both legs off, filling one with pea gravel and using the other leg as a second layer, hopefully preventing a rupture and gravel in the deep end. I'll put the Vit C tabs in the sock with the plastic wrap over the sock, with the perimeter weight sealing the edge. I used the hose/pea gravel as the perimeter weight because it can be easily moulded, lengthed or shortened to fit the stain. I'm pretty sure it's going to work well.....I'll let you know.
    DLO's Avatar
    May 2008
    Sioux City, IA
    47
    Worked perfectly. Was able to remove about 2.5-3.0 sq/ft of iron stain with a handful of Vit C tabs. The plastic wrap worked like a charm to prevent AA loss to the water.
    Mar 2007
    San Rafael, CA USA
    12,082
    Thanks for that tip for spot removal of stains. A great idea.
