Results 1 to 7 of 7
Thread: Have SWG and my first Semi-cloudy Water
    OK Pool experts....I have had some great success over the past two years with crystal clear water....today that changed. I walked down to my pool as saw the start of some cloudy water....FC is about 2.5, but PH is kind of high 8.2. Is that diminishing the chlorine? What should I do?
    B
    Ben T
    2001 Fort Wayne In Ground 18x36 Rectangle - 22,300 Gallons - Vinyl Liner -Raypak RP2100 400K BTU Gas Heater - Jacuzzi 3/4 HP Sygnet Pump - 225L Sand Filter - Aqua Rite 40K Gallon SWG (Installed June 2009).
    22,553
    Re: Have SWG and my first Semi-cloudy Water
    First thing I'd do is get your pH down. If your CH is high you probably have calcium clouding with your pH that high. Post a full set of numbers and we will have a better idea if that's the case. Also while you're at it, raise your FC up a bit.
    thanks. CYA: 60, Alk: 150 FC: 2.5 pH:8.2
    Ben T
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Lower the PH to 7.2 with Muratic Acid,
    what is your CH level?
    It's very possible this is organic in nature - you should turn off the SWG and do an overnight FC loss test.
    How are you testing the water?
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Benttt...how are you testing the water? Any CC's to report? 2.5 on your FC is kind of low for CYA of 60. 3ppm should be your minimum on FC.
    I'm using strips and estimating based on color ranges....going to pool store for printout
    Ben T
    22,553
    While the Pool Store is better than strips (maybe), which is only slightly better than nothing, it's nowhere near having your own good test kit. You'll have a much better handle on things with your own kit. See the link in my sig for the one I highly recommend.
