Results 1 to 9 of 9
Thread: Run pump while raining cats and frogs?
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,655
    FINALLY! Getting some rain here in East Texas. Problem is----just too much at one time. Gonna end up having drained 5 inches from rainfall over the past two days. Question is, is there any point in the running the pump when you have an all day rain or 2 day rain set in? Also, I haven't added chemicals in 2 days because I figured I'd just end up draining most of the bleach and stuff anyhow. What can I expect from my pool numbers when I no longer need a life preserver to go check them?
    Re: Run pump while raining cats and frogs?
    Even when it is raining I still run out and get water to test and continue to make sure I keep the chlorine level up. I would rather get wet than let my chlorine go down and get algae started.
    Above Ground 30ft x 4.5 ft deep, vinyl liner, hayward 1.5hp sand filter
    22,553
    What she said.
    You figure that even at draining 5" that's not a big percentage of the total pool volume. It's enough that you'll need to compensate for it but not enough to totally mess it up. You do need to keep testing and adding Chlorine or risk an outbreak.
    AnnaK's Avatar
    Jul 2007
    Eastern Pennsylvania
    1,134
    We just had an enormous amount of rain in eastern PA, enough to overflow the pool at the skimmer (it's an AGP). I use the free water to run several backwash and rinse cycles, then set the filter to recirculate. I do not run any tests but I do add some bleach, just because.
    AnnaK
    12,500 gal AGP, Hayward sand filter, Pentair 2-speed pump, timer.
    Please visit our Pool Issues pages for information about step weights, managing the solar cover, and PoolSkim.
    mickey4paws's Avatar
    Apr 2009
    S.E. MI
    571
    I always keep the pump running if it's raining, unless we are having bad thunderstorms where the electricity might go out. We just had a lot of rain here and like AnnaK, I use the extra water to backwash my filter.
    IG 12' x 39' - 20k Gallons - Vinyl Lined - StaRite Cristal-Flo II 26" Sand Filter - Hayward SuperPump 1 hp - Dolphin Dynamic autocleaner - Lochinvar Energyrite gas heater - Aqua Rite SWCG T-15 - TF100 Test Kit - Skimlite Duallly 9016 pole (great pole)
    Aug 2009
    North Central Texas
    1,358
    Ditto on running pump (but my pump runs, on low, 21/7 anyway, except faster when vac cleaner running for two hours), adding bleach, and using excess for backwash. Sometimes a lot of organics and dust/dirt carried in the rain, will go into the pool during storms, calling for extra chlorine.
    Hey... send some of that East Texas rain over Dallas way please. We got 1/2" couple of nights ago, and very grateful for but all it's doing now is teasing us. At least the temps are staying low, hovering around 90, and getting down in low 70s at night; felt like fall last night.
    gg=alice
    1981, 25K, IG, Blue Plaster 1996, somewhat oval, widens a bit at shallow end, 1.5" pipes, 2" at Pad, 1 separate main drain, 1 skimmer, 4 returns + dedicated cleaner return, 10 ft deep end with very fast decline from shallow, Pentair Quad 80 DE, Pentair Intelliflo VF, 3/4 HP Booster Pump (equipment pad about 8 ft below top of pool), Challanger 3/4 Trash/Emergency Pump 120v, Polaris 280 (pressure), iRobot Verro cleaner (robotic), Aquabot Turbo (robotic), Jacuzzi Tracker 4X (vacuum) Pool Blaster (Buster), Two (2) PoolSkims, Solar Breeze (solar powered top skimmer) (beta to ver. 2, release date 2010), ColorSplash LED replacement bulb. Aries 550 gal separate spa, 2002 (our 3rd and BEST spa) , BBB-Bromine
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Yep, send some of that rain out here too! We haven't had rain since March!
    Apr 2010
    East Texas
    9,655
    Most of it came down so hard and fast and ran off so there's not much left to send! Instead of just settling the dirt around my new pool-----it plum sunk a lot of it. A veritable flood. At least my shovels got washed off for the next round of dirt slinging.
    Aug 2009
    North Central Texas
    1,358
    Quote Originally Posted by woodyp
    Typical Texas "toad choker". That's why I get so excited when we have the very rare "rain" instead of inches in an hour (with gale force winds). Flash flooding is almost always to be expected because it comes down too fast to soak in.
    It tried to rain most of the day but didn't. At least it stayed just under 90 F. When we have a 40%-60% chance of rain it usually does not rain but teases the whole time. 10 miles north, south, or west, may get 5", though, with tornado warnings while we have sunshine. A couple of weeks ago a tornado touched down just 7 miles south of us. Hardly any clouds or wind here and no rain. Freaky.
