Results 1 to 9 of 9
Thread: What type of Sanitation System for New Pool
    I am setting up 13x21 foot Legacy soft side pool and would like feedback from the forum re: what type of sanitation procedure is best (i.e., ionizer; salt water; chlorine, etc.)
    Thanks.
    burt4750
    13x21 vinyl aboveground, appx 10k gallons
    Hayward Power-Flo LX 1.5hp pump on 115 volts
    Hayward sand filter
    Blue Solar Cover
    Hayward Aqua Critter
    22,553
    Re: What type of Sanitation System for New Pool
    Welcome to TFP Burt.
    Throw the ionizer out of the mix and the choice is yours! I use the Liquidator to inject chlorine but you can manually dose it or use a pump to inject it or add salt and have a SWCG generate it. It's really your preference. liquid chlorine (bleach) and a SWCG works out to be about the same cost over the life of the pool.
    The first thing to do is read Pool School and learn what it's all about. Then make your descision.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Welcome to TFP Burt. Ionizers generally do not work on their own.
    Salt and Chlorine are the same, and I would recommend either. A salt pool is a Chlorine pool. You would use a Saltwater Chlorine generator to make chlorine from the salt in your pool. I would suggest you read through pool school (button on top right of page) and that will certainly help you make a more informed decision.
    edit...sorry Bama, beat me to it, but you can see we share the same thoughts
    Isaac-1's Avatar
    SW Louisiana
    6,711
    I just wanted to comment that salt water chlorination systems are the "in thing" at the moment, the pool industry like many others go through trends, some stay around some don't. I am not personally convinced that salt water generators are the cheaper option, it is a matter of trading equipment for consumable chemicals. It is also important to understand how both systems work:
    With traditional chlorine systems you add a chemical chlorine compound into the water, depending on type this breaks down into chlorine and salt, chlorine and calcium, or chlorine and CYA stabilizer, balancing the levels of all of the above is important.
    A Salt water pool requires adding often hundred of pounds of salt to the water, then when it is being pumped through the filter it goes through an additional device that passing an electrical current through the water breaking the salt down into sodium and chlorine the chlorine does its part in the sanitation and some of it recombines to make salt again.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Issac...SWGs have been in use 40+ years They have become more affordable and popular over the past 10-15 years. No one is arguing that it may not be the most economical source of chlorination, but it is a great option and helps you avoid lugging jugs of liquid chlorine around. Using liquid chlorine or the use of a SWG to chlorinate vs other sources (trichlor tabs/Dichlor/CalHypo) is by far preferred as it does little to affect other chemical levels in your pool.
    As you mentioned either will not affect CH or CYA. Excess CH can lead to calium scale issues, while high CYA will overstabilize the pool.
    Aug 2009
    North Central Texas
    1,358
    Besides the initial up front cost of an SWG, which appears to even out in costs, over time, (and I want to get some automation in so money would go there first) the only thing that would keep me from going SWG is backwashing salted water into my very alkaline woods, the only place I have to dump water, unless it is put back in to pool. Many people, though, have the option to send water to sewer or can backwash to different locations. And most people don't need to backwash as much as I do either, so in most cases, the salt going to one area over and over for years, is not a concern.
    Otherwise there are just too many people who love their SWG systems, to argue against them. I'm considering the liquid chlorine Liquidator, though. They are very inexpensive upfront.
    gg=alice
    1981, 25K, IG, Blue Plaster 1996, somewhat oval, widens a bit at shallow end, 1.5" pipes, 2" at Pad, 1 separate main drain, 1 skimmer, 4 returns + dedicated cleaner return, 10 ft deep end with very fast decline from shallow, Pentair Quad 80 DE, Pentair Intelliflo VF, 3/4 HP Booster Pump (equipment pad about 8 ft below top of pool), Challanger 3/4 Trash/Emergency Pump 120v, Polaris 280 (pressure), iRobot Verro cleaner (robotic), Aquabot Turbo (robotic), Jacuzzi Tracker 4X (vacuum) Pool Blaster (Buster), Two (2) PoolSkims, Solar Breeze (solar powered top skimmer) (beta to ver. 2, release date 2010), ColorSplash LED replacement bulb. Aries 550 gal separate spa, 2002 (our 3rd and BEST spa) , BBB-Bromine
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Quote Originally Posted by dmanb2b
    I did not mean to imply anyone here is pushing SWG systems as an economic advantage, however out in the real world it seems there is a trend of selling SWG as better and cheaper in the long run, without mentioning the upkeep costs, etc.
    Ike.
    Aug 2009
    Hattiesburg, MS
    84
    Salt systems for AGP's are reasonable. That's what we are running. Once you have done your research at pool school and weighed your pros and cons check out nationalpoolwholesalers.com. They have a very good selection of filtration systems and I cannot find anyone to beat their prices not even walmart.com. Oh yeah, shipping is free.
    Good luck...
    18x33 Delair Sunsation GS AGP Oval 4 shallow-6 deep mostly buried
    Sep 2008
    The Woodlands, Texas, USA
    243
    I love my SWG. Convenience, stable pool chemistry, and did I mention convenience?!
    IG 24k plaster with overflow spa. Goldline PS-8 SWG. Tristar 0.75 HP filter pump, Polaris 280, large cartridge filter, 400k BTU NG Max-E-Therm HD, SR Smith Turbo Twister, Life Saver pool fence, ORP managed.
