Results 1 to 7 of 7
Thread: CYA
    Apr 2010
    Fairfield, New Jersey
    22
    CYA
    Hi Everyone,
    First I have to thank the answers I got on this site my pool is better then ever. One question- my CYA has been creeping up. It was 50 now its 70 I am using bleach. What causes the rise? The pool calculator wants me to replace 43% of the water. Im thinking I should do a CYA test on my fill water first.
    Kenny
    13K gal, Vinyl, 24' x 52" AGP, 1 HP pump, sand filter, 75 GPM, Chlorine
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: CYA
    Your fill water doesn't have CYA in it. CYA is added only in stabilized chlorine like trichlor and dichlor, or directly in stabilizer/conditioner.
    Butterfly's Avatar
    South Carolina
    10,045
    Re: CYA
    Testing error? What test kit are you using?
    You're done SLAMing when:
    Apr 2010
    22
    Re: CYA
    Quote Originally Posted by Butterfly
    TF 100
    and I try to see that black dot .. you know if you look real hard you may be able to add more fluid and bring the CYA down .. it is a funky test i guess as good as your eyes are
    Butterfly's Avatar
    South Carolina
    10,045
    Re: CYA
    Well, as JohnT mentioned, have you added any stabilized chlorine?
    You could order a CYA standard solution test to verify your CYA test results.
    Consistency in testing is very important, like testing around the same time of day in the same lighting.
    Here's Taylor instructions w/pics for the CYA test: http://www.taylortechnologies.com/Chemi ... ntentID=36
    Jan 2009
    Cupertino, CA
    1,966
    Re: CYA
    I find that wiggling the tube a little helps me identify the black dot when it's mostly obscured but not completely.
    --paulr
    BBB "Intermediate Swimmer"
    Re: CYA
    Another suggestion is to do the test, then pour the water back into the container and do it a second time. Then pour it back and have someone else do it; don't tell them your result so you don't bias their findings. The two of you should get more or less the same result.
