Thread: Stumped
    CT.
    72
    Stumped
    ok, pool has been great since opening. On Tuesday I added some salt (nonSWG) to bring the salt to 1500. Since that change I can not keep CL? All other levels are good PH 7.5 TA 100, CH 220, CYA 50
    I have been using a DPD Taylor 2005 kit with no issues.
    16,000 gallon outdoor in-ground 16'x32' Kidney painted concrete pool; Hayward super pump, Hayward pro Grid 3620 DE filter(using Fiber Clear). No Heater. 250 gallon stand alone Jacuzzi hot tub .
    30,395
    Re: Stumped
    Salt is unrelated to the pools ability to maintain FC. Most likely you have unseen organics (algae) in your pool and it needs to be shocked.
    CT.
    72
    Re: Stumped
    ok, Will try the shock route? just added 1 jug that should get it to 5 then will head out to get more?
    Jan 2009
    Cupertino, CA
    1,966
    Re: Stumped
    FC 5 would be a normal level for CYA 50. Definitely go get more jugs, for shocking you want FC up in the 15-20 neighborhood.
    --paulr
    BBB "Intermediate Swimmer"
    Re: Stumped
    When shocking it helps a great deal to go up to shock level all at once. If you add 5 ppm of chlorine now and 5 ppm of chlorine later you won't kill anywhere near as much algae as if you add 10 ppm of chlorine all at once.
    CT.
    72
    Re: Stumped
    used Cal hypo along with the Bleach to get to shock level....
