Page 8 of 12 FirstFirst ... 567891011 ... LastLast
Results 141 to 160 of 221
Thread: The Pool Calculator
  1. Back To Top    #141
    Re: The Pool Calculator
    Hello again, and good morning! Java script is enabled. I'm using ie 8. All other values are computing. Free Chlorine is the only one that isn't giving me results. no matter what numbers I enter into FC or any other categories, the FC result is always to add 0 bleach 6 percent, as well as 0's all the way across the FC results cell. I didn't have any problems w/ it until about two days ago. have tried restarting the computer, in addition to everything I mentioned above. ideas from here? have two families coming over to swim today. :/
    17 ,000 gal AG vinyl; Hayward 1.5 HP; Hayward sand filter; Hayward auto chl tab feeder (unused, except when nec.); Hayward Pool Heater + solar cover.
  2. Back To Top    #142
    22,469
    Are you tabbing into each cell or clicking into them?
    I've seen an extra space or period in the cells be hidden and stop the calc.
  3. Back To Top    #143
    I'm tabbing.
  4. Back To Top    #144
    Dec 2010
    San Diego, CA
    1,137
    X2 on the spaces issue
    15,600 Gallon, 16' x 32' In-Ground Vinyl Pool
    Pentair VS 3050 pump, Quad DE 60 filter and SunTouch controller
    8 gallon Liquidator, Aquatherm EcoSun Solar Panels, 2 wheel ThePoolCleaner
  5. Back To Top    #145
    There aren't any extra spaces anywhere. I've reentered the values numerous times, tabbing all the way through and making sure there aren't any spaces. No matter what I do, the result for FC is 0. I get results for every other value. ANY other suggestions, please??? This just seems crazy to me. Meanwhile, I'm going to see whether I can just use the browser on my phone....
  6. Back To Top    #146
    22,469
    Once you're on the PC (pool calc) page hit refresh and see if that works. If it doesn't, close everything and delete your browsing history and cookies.
  7. Back To Top    #147
    I did hit refresh, did close the browser, did delete cookies, (including checked form-fill), and also have tried restarting the computer--all of which I listed in my original post. I honestly cannot think of anything else to try. I build computers and repair computers and software. i am truly befuddled! It makes NO SENSE to me that all cells work except FC. Maybe I need to query one of my computer guru forums at this point? Grrrrr!
  8. Back To Top    #148
    Have you tried re-entering the % setting and changed the form of chlorine selected in the popup to see if either of those get it going again?
  9. Back To Top    #149
    Actually, yes. I did try reentering the settings and changing the form of chlorine selected. Now, I'd like to share what turned was the problem so that everybody who tried to help me solve it will know that they all had very good ideas and that I am really just a dumb blond (literally). From now on, I will TRY to enter the Now and Target numbers into the correct columns instead of the other way around. I can't wait to see how badly I've screwed up this pool over the past couple of days. Thanks for your help! Now I have to sign off so that I can go buy muriatic acid (as well as who-knows-what-else)!
    Cheers,
    Kristine
  10. Back To Top    #150
    WestSidePool's Avatar
    Cincinnati, OH
    424
    Pool Calculator app for the iPad?
    Is there a Pool Calculator app for the iPad? This may already be in the works, but I thought I would suggest it anyways.
    Eric
    IG 17x33 Grecian - Vinyl Liner (21k gallons), Hayward Pro-Grid DE 4820 filter, Hayward Super Pump, CompuPool SWG CPSC36, TF-100 Test Kit
  11. Back To Top    #151
    Jun 2011
    AustinTexas Hill Country
    12
    Still patiently waiting for a BB ap!!! I know we are the minority but still out here!!!
    19,000 gallon, SWG, IG; Plaster/pebble, cartridge filter, Zodiac 2hp variable speed
  12. Back To Top    #152
    Jun 2011
    12
    Not even available on Ipad????
  13. Back To Top    #153
    I know the answer is coming a little late, but you might take a look at thePoolMonitor.
    http://thePoolMonitor.com
    There is a mobile app that will work on the iPad, but it is actually designed for the iPhone.
    J.Ollman
    18k gallon, in-ground gunite, attached spa, sand filter
  14. Back To Top    #154
    I too have the issue with the iPhone version losing it's settings after the app is fully closed or phone rebooted. It's very disappointing too that 7 months after users have been reporting the issue, it's hasn't been fixed!! Especially when Jason mentioned one of his reasons for selling it was because pSiFlow would be putting more development into the app that he couldn't
    1)18,900 gallons 28 x 15 ft rectangle
    2)Sand
    3)IG
    4)Concrete
    5)Not sure about my pump
  15. Back To Top    #155
    Aquatica's Avatar
    Jun 2010
    Nassau, Bahamas
    514
    Quote Originally Posted by thePoolMonitor
    can reports be emailed from The Pool Monitor App?
  16. Back To Top    #156
    Reports can be saved to .pdf or other formats.
    J.Ollman
  17. Back To Top    #157
    May 2012
    North of Charlotte, NC
    312
    I will add larger input fields to the wish list.
    The current settings are saved in a cookie. That should work unless you have cookies disabled. Some web browsers always disable cookies for pages loaded from your local machine, so if you saved a copy of the page to your local drive and are using that, it might not work.
    I use Google Chrome as my browser, anyone out there know what setting I have to manipulate to allow me to have my pool calc setting to stay and not revert back to default ? I see a few choices but not sure what to select ? Anybody out there use Chrome that knows what I'm talking about ??
    24,000 Gallon Vinyl Grecian IG,Triton2 Sand Filter / Pentair Super Flo 1 HP Dual Speed Pump ,
    Stenner Peristaltic Pump Injection w/15 gal drum,Stubbed up supply/return for future solar panels :)
    TF100 Rocks !! Pool School....
  18. Back To Top    #158
    Sarnia, Ontario Canada
    162
    Is it normal for the iOS app to clear all the setup data upon exiting the app? The app is great, but I would rather not have to go and input my pool volume etc.
    20x47' double roman vinyl liner pool. Pentair EasyTouch 8PSC-IC40, 011018 Pentair IntelliFlo, Pentair Clean & Clear Plus Filter CCP420, Pentair 120V IntelliBrite LED, Cleardeck indeck solar reel, 530 sq' solar system Polaris 9300xi robot, Interfab Turbotwister slide, S.R. Smith T7 diving board, deck jets vinyl-liner-pool-build-in-ontario-canada-new-pictures-t30213.html
  19. Back To Top    #159
    Yes, losing settings is a known problem in the iOS version. Sadly, there is no sign that they are going to fix it any time soon.
  20. Back To Top    #160
    Dear All,
    The Pool Calculator seems to be down this morning, at least for me. I cannot access it using Google Chrome or Firefox. I simply get a "forbidden" message, a la this:
    Forbidden
    You don't have permission to access / on this server.
    Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.
    Can anyone advise?
    best wishes,
    David
    11,500 gal. rectangular cement, 11 x 28 (built c1930); Hayward S180T sand filter; Hayward Max-Flo II 3/4 HP pump
