Thread: Question regarding Ascorbic Acid treatment
    After confirming stain type, reading here about the ascorbic acid treatment, and ordering the acid (2.2 lbs from Amazon for $36.95 with free shipping) I will be doing this treatment next week. My question is..............
    I saw where the chlorine should be brought back up slowly. Can I do this with the SG at the "normal" setting? Is that too fast? Too slow?
    13,900 gallon exposed aggregate pool, DE filter, 1.5 hp pump, 2 waterfalls, Navigator pool cleaner. Pool is screened in.
    Re: Question regarding Ascorbic Acid treatment
    Yes you can use a SWG. You should run the SWG at no more than 1/3 of the usual percentage to start with, perhaps even a little less than that.
    Thank you very much!
    Update - performed AA treatment yesterday after adding the suggested algaecide, lowering PH to 7.0 & allowing chlorine to get to zero (almost).
    I witnessed a miracle! Every stain in this 5 year old pool was gone within an hour . (Used all 2.2 lbs of AA I ordered, what else was I going to do with it, take it as a vitamin? )
    I have since used washing soda to bring up both my PH & Alk to suggested levels. Since I use a SG, and I normally run it at 60%, I turned it back on this afternoon at 15%. Obviously the chlorine levels will never get where they need to be at this %. Question is............how often should I bump up the % to get chlorine where it is needed, keeping in mind the SG will also raise the PH, or should I raise the chlorine to the necessary levels using liquid chlorine (I already have 4 gal on hand). If I take this approach, how much should I add at any one time and how often to bring the chlorine back up slowly as suggested?
    Thanks for your help, you guys saved me a $$$$$ by posting the instructions for the AA treatment! (After this is all balanced.........it's on to Borax!)
