Thread: Tab for skimmer door is broken
    There is supposed to be a plastic tab on my skimmer that keeps the weir door from swinging out (beyond vertical) into the pool. On one of the skimmers that tab is broken off, so the door flops back and forth. Any recommendation about how to repair that (e.g., some kind of glue and plastic)? Thanks in advance.
    gonefishin's Avatar
    Joliet, Il.
    I'm sure others may have some suggestions as well. You may be able to repair the tab back onto the door...but I'm thinking it may break again and again. You may want to take a ride to the pool store and see how much a new one is.
    good luck! and let us know what you decide...and how it holds up
    21' Aqua-Leader AGP (10,200 gallons).
    Hayward cartridge filter and two speed pump.
    Aqua-Cal HeatWave 100k (HeatPump)
    Salt 3200ppm (in non-salt water pool)
    Borates 20ppm (slowly raising)
    Aqua-Rite SWG
