Results 1 to 7 of 7
Thread: Size of liquidator?
    Jun 2010
    Pearl, MS
    49
    Size of liquidator?
    Just started using BBB; so far, great results. I'd like to automate a bit with the Liquidator, but space is limited near the pump/filter. What are the approximate dimensions of the 4 gallon model? Couldn't find that anywhere. Thanks!
    Larry
    16x28 vinyl inground kidney, 1HP pump, sand filter, Compupool SWG, 11K gallons
    22,553
    Re: Size of liquidator?
    The 8 gallon is 14½" x 14½" x 29½". I just went and measured it. I think the 4 gallon is the same width and height just a little shorter. I'd highly recommend the 8 gal unless you absolutely cannot fit it. You'll appreciate it when fillup time rolls around.
    24' x 52" Round AGP. 2hp/hp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,643
    Ok, where's a good place to buy a liquidator for next year?
    Received this from the company. I went with the 8 gal. based on recommendations here.
    Thank you for your inquiry, the four gallon (residential R-101) is 14 3/4 x 14 3/4 x 23 1/2
    and the 8 gallon (commercial C- 201) is 14 3/4 x 14 3/4 x 29 1/2.
    21000 Gallons I/G,,Vinyl,, 1.5 H.P. Hayward Pump,, Hayward Sand Filter S244T.. Liquidator.
    Jun 2010
    Pearl, MS
    49
    Thanks for the replies. Either unit will fit perfectly in my application. Now I'm wondering if 8 gallons will degrade before it's used. My pool is 11000 gallons, inground. Shouldn't 8 gallons last for several weeks?
    Larry
    flyboy320's Avatar
    Jul 2009
    Burlington, Ontario, Canada
    216
    Quote Originally Posted by woodyp
    Best place I found was http://www.poolservicestech.com
    They were by far the cheapest, but more importantly had the best customer service I have had in a very long time. Can't go wrong with these folks...
    10K gal IG, vinyl, 1 HP Jandy Stealth pump, Jandy CS cartridge filter, Delta UV system, Hasa Liquidator
    22,553
    It won't degrade enough to be a problem in the time it takes to use it up.
    There are a couple of companies that are members here that sell them.
    http://www.Poolservicestech.com are giving TFP supporters a really good deal.
    http://www.poolandspawarehouse.com also sells them an give TFP supporters a discount.
    Once you become a supporter you can get the code for the discount.
