View Poll Results: To Phos Free or Not?
Voters
3. You may not vote on this poll
  • Phos-Free is a scam.
    2 66.67%
  • Phos-Free has worked in my pool.
    0 0%
  • Phos-Free is useful for hands-off pool owners.
    0 0%
  • Phos-Free is a waste if chem levels are in check.
    1 33.33%
Thread: Green Algae? at Waterline
    Mar 2010
    Tustin, CA (Orange County)
    40
    Hello,
    Water chem is right on and there are no issues with algae in the actual pool; however, there is a bright green something growing on the grout right above the waterline. Not sure if algae or moss/mold/fungus.
    The 2008 post below mentioned brushing a 50/50 clorox solution on the problem areas:
    algae-spots-on-waterline-tile-t9199.html?hilit=grout
    Is this still an accurate process to remove the problem? Saw "Green Out" mentioned somewhere but not sure if it is used for the same situation or if that product works.
    Also, I searched "phos-free" and came up with a couple opinions on it. Just wanted to throw it out there again and get a really good handle on TFP member's thoughts cuz it's something Leslies is pushing hard core and we have been adding to the pool like faithful lemmings. Not sure if it makes a difference for dark bottom pool owners.
    Thanks!
    Curacao Quartz Finish (grey plaster with grey, black, blue & white quartz)
    29k gallon IG
    Pentair WhisperFlo Pump
    Pentair FNS Filter
    Hayward SwimPure T15 SWG
    30,419
    Re: Green Algae? at Waterline
    I would simply put clorox in a spray bottle and spray it directly on the grout. It should clear up rather quickly although there may be a slight staining left behind. Brushing with a deck brush and maybe even just a little soap would be helpful in clearing up any residual stains.
    Skip the phos-free. You are wasting your money.
    Phos Free is nearly always a waste of money. If you maintain your FC levels appropriately there is no need for Phos Free.
