Thread: POOL IS BECOMING DISCOLORED, LOOKS LIKE A RUST COLOR SKIM.
    CAN ANYONE TELL ME WHAT I AM DOING WRONG. WATER HAS BEEN CLOUDY FOR ABOUT A MONTH NOW. HAVE HAD IT TESTED TWICE AND PUT IN THE CHEMICALS THAT WERE RECOMMENDED BY THE POOL PLACE. NOW THAT IT HAS CLEARED SOME THE LADDER, WHICH IS WHITE HAS A RUST COLOR SKIM ON IT ALONG WITH THE FILTER, AND THE CENTER OF THE POOL LINER.
    Debbie
    Leander, TX (nw of Austin)
    15x30 AG converting from BaquaPoo to BBB
    Can't wait to see sparkling water again!
    Hi Charlie, Read the stickies, found in my signature.
    Post your numbers and more info about your pool... plaster, vinyl fiberglass, filter type, water source... and someone will be able to help you.
    Welcome to TFP!
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
