Thread: Laars lite 2 - any ideas whats up with it?
    Hi all,
    I have a fairly new Laars lite 2 natural gas boiler for my below ground pool.
    This heater has had a problem with the pilot light which turned out to be a copper wire that I have replaced and the pilot light now stays on..
    however it will not fire up.
    I took off the wires during the installation of the new copper wire and possibly mixed them up does anyone have a colour photo of the inside of one of these boilers.. I have a wiring diagram but it is hard to follow.
    I have read that there is a way of bypassing the pressure valves and safety cut offs etc to test the switches etc .. any ideas??
    Many thanks
    Raydo123
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: Laars lite 2 - any ideas whats up with it?
    Welcome to TFP!!
    You can 'jump' the individual switches to see which one(s) is/ are bad. All you need to do is insert a small continuous wire (or gator clips) to take the switch in question out of the loop. It's been a while since I've had to play this game.
    IF you do this and the heater fires - DO NOT CONTINUE TO RUN THE HEATER WITHOUT REPLACING THE DEFECTIVE PART!!! These switches are there for a reason - no one wants you to die prematurely
    Luv& Luk
    -Ted
