Thread: New motor for pump
    New motor for pump
    I have a new pentair whisperflo pump and want to change the single speed motor to a dual speed. Plan to keep the same horse power 1.5, Generally speaking are all the whisper flo pumps the same but with different motors.
    Can anyone recommend a place to buy the new dual speed pump?
    16,000 Plaster/Gunite - Pentair FNS Plus Fiberglass D.E. Filter
    Heat Siphon Heat Pump Z375HP- Hayward Pro Logic PL-P4 Automation
    Hayward Chlorinator Cell T-CELL-9 - Waterway SVL5 Pump
    A.O. Smith Two Speed Motor B983 - Solar Blanket - Polaris 380
    Test Kit K-2006c
    22,553
    Re: New motor for pump
    Just look at the nameplate data & multiply the SF times HP, then match frame and voltage to the high speed of the new motor and you'll be fine. Google is your friend in finding a good place to buy a replacement motor.
    sonflower's Avatar
    Jun 2010
    Fort Worth, TX
    157
    We purchased our replacement pool pump and various other parts at poolpartsonline.com.
    Pool: (2003) IG Plaster 14,209 gallon (Water Surface 421 sq. ft.) ~ Spa: 18" raised kidney
    Triple spillway (Waterfall) ~ With 6' slide ~ Hayward's Goldline Controls Aqua Rite Digital Electronic Chlorine Generator (Salt System) ~ 40K Salt Cell ~
    ~ AquaLink RS -4 ~ Purex Whisper Flow 2 HP~ Aquatech 60 sq. ft. DE Filter Normal Pressure 22 # ~ MiniMax NT (Propane) Heater 400,000 BTU ~ Jandy Valve Actuator ~Letro Legend Cleaner ~ K-2006 & K-1766 Test Kits
