Thread: New plaster help, streaks still there
    I had Midnight Blue Diamondbrite installed on a Friday. they added the water that night but PB couldn't come out until Monday to get started with the acid/brushing etc. The told me it would be no issue to not brush over the weekend (I wasn't given my brush yet so didn't have much choice). On monday they came out, added the acid and now brushing 2 times a day. In several areas, including the baja shelf, there where lighter streaky areas before the acid was added where it looks like the sediment or dust settled. They have darkened some but still fairly noticeable. By not brushing for the first three days after the plaster was done and water was added, is this the reason the streaky areas are there and something I should demand the PB remedy (if at all possible)?
    24,000 gal free form with slide feature
    3.5ft to 5.5ft Sport Pool
    Midnight Blue Diamond Brite
    Intellichlor IC-40
    Intelliflow VS-3050
    Easy Touch 4
    Clean and Clear Cartridge
    Re: New plaster help, streaks still there
    Dark plaster will show streaks in the beginning. I am pretty sure they come out with continued brushing, but it can take some time. Read the new plaster thread in pool school for more info.
    http://www.troublefreepool.com/pool-...aster_start-up
    coloeb,
    20k gal. IG fiberglass/plaster rectangle 32'x16'
    Hayward Superpump 3/4 H.P. primary Hayward model 5060 Booster Pump
    Hayward Pro Series High Rate Sand Filter
    Pentair Model 320 automatic Chlorine/bromine in-line feeder
