Thread: New pump recommendations
    I've been researching all evening trying to figure out if my current sand filter is adequately sized for the pool.
    Sand Filter: Swim Pro 236T with this:
    Effective filtration area: 2.53ft2
    filtration rate: 25 gpm/ft2
    filter & backwash design flow rate: 63 gpm
    Pump is 1.5HP
    From what I can figure the minimum flow rate I need for 23800 gallons of water in my pool is 49.58. I think this filter is sufficient for the pool but am just not sure. I think the pump is going to die at some point this summer so I want to research and figure out what pump would be a good choice before it dies so I already have it onsite.
    Also if the above is correct, how long should I have to run the pump to clean the pool sufficiently?
    Above Ground 30ft x 4.5 ft deep, vinyl liner, hayward 1.5hp sand filter
    South Central NJ
    3,192
    Re: New pump recommendations
    I would drop the HP of the pump to a 3/4 or 1 HP. Your 1.5 is a bit much.
    Scott
    Owner of - PoolGuyNJ LLC
    22,551
    I would agree with Scott's recommendation and just add to make it a 2-speed.
    The Filter is ok for that size pool. At 50gpm you'll need to run your pump about 8 hours to get one turnover and that's what's recommended.
