Thread: Which pump to use?
    Feb 2010
    Houston, TX
    271
    Which pump to use?
    As some of you here already know, I recently got a used AGP. It came with a 1HP Hayward Powerflo Matrix (single speed), and a Hayward 166t sand filter. I plan on upgrading to the 244t at the beginning of next year (maybe sooner but I doubt it).
    From the little I understand about flow rates and such, I think this pump is too big for the filter. I also have a 2 speed 2HP pump on my hot tub. So my question is, would it be better to use the 1HP or the 2HP 2 speed on the pool? If you need more information, I'll try to get whatever I can.
    Thanks everyone!
    John
    24' round Vogue AGP 12,000 gal. Flotec AT251001-01 1HP pump, Hayward S310T2 sand filter, Aquarite SWG T-15
    TF-100 (found at TF Test Kits) with Speedstir and Samplesizer
    Re: Which pump to use?
    I certainly would recommend a larger filter, but the 166t isn't out of the question or anything like that.
    The 2 HP two speed pump on low speed will use significantly less electricity than the 1 HP on it's one speed and work better with the filter.
    Ideally you want a larger filter and a 1 HP two speed, but various other combinations will work acceptably.
    Feb 2010
    Houston, TX
    271
    So do you think the Hayward will work okay until I upgrade the filter? I just want to make sure it's not so oversized that it will blow stuff through the filter back into the pool. If it will work okay for now, I won't bother switching them out. I don't care about the electricity costs, after all our bill more than doubles when we put up Christmas lights and I just deal with it.
    Thanks Jason, and anyone else who answers.
    John
    Feb 2010
    Houston, TX
    271
    Got worked down the page quickly today so...
    John
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Your current set-up will work fine for now and is not far from typical pool store set-ups...ie oversized pump and undersized filter, but is not optimal. The s244 (300lb), may be a little overkil but by far good enogh. I have the S220t (250lb) and a 0.5hp pump, two solar panels and intex swg and no long runs. Good flow and I backwashed 3 times last season. Like jason said a 1hp 2-speed would be your best bet if you go with the 244T.
    Hope that helps
    Feb 2010
    Houston, TX
    271
    Thanks dman, helps a lot. The 244t may be overkill, but no one here ever wishes they would've went smaller! Besides, I have a lot of time to make up my mind, so I may end up going with the 220t instead. But like I said, not until the beg. of next year. I want to replace the pump sooner, but I may just get them together.
    Anyways, thanks for clearing that up.
    John
